84 Users Online (83 Members):
Forums >> Revit Building >> Technical Support >> Shear Wall Length
28 Posts No Rating |
I have modified the standard wall tag to represent shear wall location and type however I want to be able to show the length of the shear wall as well. I can not seem to figure out how to get the tag to show the length of the wall. I am only having this problem with shear walls that are actually the full length of a wall. If I create parts within a wall the part tag will represent the length of the specified shear wall.
Within in the part tag family editor there already is a "length" label which allows me to do this however in the standard wall tag there is not "length" lable. If I create a shared parameter and apply it to the tag it does not show the length of a wall when loaded into a project. How can I add that label the the wall tag family category or assign it to automatically popluate the tag with the wall length?
I've not uploaded this annotation, as I have not worked out all the bugs and added the features that I would like. Take a look maybe you can improve on it.
Shear Wall Symbol |
Thu, Oct 22, 2009 at 10:29:41 AM
Shear wall tag with label that reads wall length |
Fri, Oct 21, 2011 at 5:57:35 PM
Shear studs on Steel Beam Family |
Wed, Jul 25, 2012 at 5:48:17 PM
Shear Wall Calculations using Revit !! |
Fri, Nov 21, 2008 at 4:03:36 AM
wall tags - shear wall tag on exterior (sheathed) side of wall? |
Tue, May 26, 2009 at 9:55:16 AM
Members: | 1992502 | Objects: | 22881 | Forum Posts: | 152184 | Job Listings: | 3 |
