175 Users Online (174 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> family host problem
Mon, Nov 12, 2012 at 12:32:58 PM | family host problem
#16
JohnCubed
I'm having the same problem and with the furniture family ONLY. I know how to use Cut and Paste Aligned as it works as designed for other families. Turning off the floor in visibility graphics doesn't work.
Mon, Nov 12, 2012 at 12:47:30 PM | family host problem
#17
JohnCubed
No, I'm not playing around with the workplane. And like I mentioned other families (plumbing, casework) are working just fine so everything must be in order in this regard. Attached is an example of an item in question. It's a bed from the Revit stock library. Host is Level 2 but there is no offset option with this family.
Mon, Nov 12, 2012 at 1:02:52 PM | family host problem
#18
3.5 Stars: 389 Votes
Pull down that host level and see if you can change it to the next level.
Mon, Nov 12, 2012 at 2:14:47 PM | family host problem
#19
JohnCubed
I've already tried that with no effect. It stays at Level 2. Have you been able to make this work on your machine? And, if so, how.
Edited on: Mon, Nov 12, 2012 at 2:17:20 PM
Edited on: Mon, Nov 12, 2012 at 2:29:25 PM
Wed, Nov 14, 2012 at 11:45:42 AM | family host problem
#20
JohnCubed
To make a long story short: I solved the problem by redrawing all the floors.
Mon, Oct 27, 2014 at 11:21:52 PM | family host problem
#21
loganlkemp
Easiest way around this is to group all the furniture and fixures, then copy and paste them into a seperate project (project 2), and then copy and paste them back into the original project on the desired level. If you have hosted fixtures such as bathtubs, they will dissapear when you paste into (project 2), but when you bring them back into the original you can use the "restore all excluded" tool.
Tue, Oct 28, 2014 at 8:37:06 AM | family host problem
#22
loganlkemp,
There is no need to group and no need to paste in a seperate project.  For multi-level projects just copy the selected the objects to clipboard and paste to elected levels.
If you want to use a group for other reasons in other projects, you can group, then use save as/ library / group to save the group.
Fri, Sep 4, 2015 at 2:59:04 PM | family host problem
#23
jrsnbarn
I'm having this problem with Revit 2016. I am placing families into a group on Level 1 and they are getting hosted to the floor not the level. When that same group is on another level, those families remian on Level 1.
Fri, Sep 4, 2015 at 3:45:21 PM | family host problem
#24
jrsnbarn
I have a solution: remove the problematic elements from the group and the rehost button will now appear when you select the item. Get the item into a view where you can select the level line and then rehost it to the level. Put in back in the group and it will behave the way you want it to.
Nested Family referencing Host family
Fri, May 10, 2013 at 7:15:14 AM
Nested family missing when host family is loaded into project
Wed, May 13, 2009 at 7:36:11 PM
Problem with revit family (attic stairway)
Sun, Aug 31, 2014 at 1:03:43 PM
skylight placed on sidewalk
Wed, Aug 15, 2007 at 3:59:40 PM
Changing Family Host In Project
Thu, Feb 21, 2019 at 5:33:32 PM
Page generation time: 1.7715
