74 Users Online (73 Members):
Forums >> Community >> The Studio >> new 2 revit
4 Posts No Rating |
i'm trying to make a recessed fire extinguisher family cabinet and when i do a void extrusion it doesn't seem to remove the wall material. when i view it in "hidden" or "shaded w/edges" in a 3-D view it doesn't seem to look right. however in a wireframe setting it definitely subracted a portion of the wall. anyhow, i'm wondering if there's any way of getting around this?
.b.
did you make sure you use the cut tools to tell the void what to cut? post a screeny...
As eldad suggested.
Be sure to use the cut geometry tool, select the void then the wall to tell the void to physically cut the wall.
4 Posts No Rating |
thanks a lot....didn't realize that tool was there nor how to properly utalize the void solid tool apparently.
Revit for Construction Documents [ 1 2 ] |
Tue, Jan 24, 2012 at 10:57:38 AM
20
4D simulation in Revit? [ 1 2 ] |
Mon, Jan 17, 2011 at 11:27:39 AM
18
I need to open a Revit 2011 file into the Revit 2009 ? Are there any way ? [ 1 2 ] |
Thu, Jan 6, 2011 at 3:25:02 PM
18
We are looking for Revit Users [ 1 2 ] |
Thu, Mar 31, 2011 at 5:15:24 PM
17
AutoCad vs Revit [ 1 2 ] |
Thu, Aug 4, 2011 at 1:58:52 PM
16
Members: | 1993979 | Objects: | 22882 | Forum Posts: | 152185 | Job Listings: | 3 |
