155 Users Online (154 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> plotting exported files to match revit originals
Mon, May 9, 2011 at 5:27:24 PM | plotting exported files to match revit originals
pepsiqueen
pepsiqueen Avatar
so, i export a floorplan from revit, open it in cad, and use the .pcp file to create a new .ctb file. everything is set to the AIA standard.
when i plot it in autocad, it is in color and not black/white/grey. (there are 'existing' phase walls)
what am i missing? how do i get the autocad version to plot to look just like the revit version?
I have been using revit for years and have never actually had to go backwards like this...
I'd rather be riding at whistler. or highland. thats good too.
Tue, May 10, 2011 at 10:59:45 AM | plotting exported files to match revit originals
coreed
coreed Avatar
4 Stars: 16 Votes
in your ctb file you have to set all the colors to black
Edited on: Tue, May 10, 2011 at 11:00:26 AM
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Tue, May 10, 2011 at 11:07:41 AM | plotting exported files to match revit originals
pepsiqueen
pepsiqueen Avatar
problem with doing that is that in revit, the drawing is not all black, existing items are grey. i suppose i could hunt and peck to change all the 'existing' layers to grey, but that just seems so time consuming. <p> As a person who is trying to get my office to transition over its things like that that make it harder. (even though in the end revit will be soooo much better... but no one seems to understand that! we have the software, yet no one seems willing to try it!)
Tue, May 10, 2011 at 11:33:46 AM | plotting exported files to match revit originals
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
Why not take the time to modify if needed, to match the lineweights of revit to AIA, silly I think. Just another imposed restriction from likely an unknowing person/agency.
Tue, May 10, 2011 at 11:44:13 AM | plotting exported files to match revit originals
pepsiqueen
pepsiqueen Avatar
i dont care if they match AIA lineweights/layers or not, at this point i just want to be able to export a sheet from revit and plot it from autocad such that it looks just like the same sheet printed from revit. seems like a simple task, but i have never been able to acomplish it in over 7 years using revit!
Tue, May 10, 2011 at 11:51:22 AM | plotting exported files to match revit originals
coreed
coreed Avatar
4 Stars: 16 Votes
i mean in your Atuocad ctb file. i though you wanted the autocad file to plot in black.
Edited on: Tue, May 10, 2011 at 11:53:26 AM
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Tue, May 10, 2011 at 12:05:35 PM | plotting exported files to match revit originals
pepsiqueen
pepsiqueen Avatar
coreed-
i can get it to print in all black... but thats not what it looks like in revit. in revit existing items are shown in grey. there should be a way to setup the export layers in revit such that the .pcp generated allows the .dwg file to plot such that you couldnt tell a revit plot apart from an acad one.
Tue, May 10, 2011 at 1:03:18 PM | plotting exported files to match revit originals
coreed
coreed Avatar
4 Stars: 16 Votes
i get it now. you want those gray items to print in gray when exported without having to manually adjust the ctb file. they have enhacned this process in 2012. don't know if it addresses what your are trying to do.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Thu, May 12, 2011 at 1:18:29 PM | plotting exported files to match revit originals
pepsiqueen
pepsiqueen Avatar
i havent installed 2012 yet, so hopefully it solves the issue.
Thu, May 12, 2011 at 2:29:07 PM | plotting exported files to match revit originals
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
I don't get why are you trying to print it using Acad?
P.S. Whistler was my Honeymoon spot.
Mon, May 16, 2011 at 5:36:16 PM | plotting exported files to match revit originals
pepsiqueen
pepsiqueen Avatar
i am the only one in my office using revit - and there needs to be a way for a revit-dumb person to take a sheet and work on it (in acad) , and print it so that is seamlessly integrates into the rest of the printed set that i may have printed out of revit. (so that i can go on vacation and the projects i am working on can be worked on by other people if necessary. this means i have to export sheets to .dwg before i go anywhere)
Its stupid, i know, but at the same time it sounds like a simple request that is in fact quite difficult to achieve.
Mon, Nov 7, 2011 at 2:30:30 PM | plotting exported files to match revit originals
Noe17
DO YOU CAN RESOLVE  PCP PLOT AUTO CAD I HAVE THE SAME PROBLEM
plotting exported CADfiles
Tue, Jul 10, 2007 at 12:46:30 PM
Understanding Revit Plotting
Fri, Nov 25, 2005 at 1:36:18 AM
11
PRN plot files
Sat, Apr 9, 2005 at 1:40:49 AM
Plotting Revit Projects in AutoCAD 101
Fri, Mar 26, 2010 at 7:12:17 AM
FILLED REGIONS EXPORTED TO AUTOCAD
Thu, Nov 6, 2008 at 4:45:16 PM
Page generation time: 1.5794
