75 Users Online (73 Members):
Forums >> Revit Building >> Technical Support >> curvy sketch extrusion
To make that form, and make sure that the curves that you are describing are armonic, use the radius of the (arc 1) as a guide to snap the center of the next (arc 2).
That works for both concave and convex curves, the extrusion you want to make follows that same rule.
If you need to describe it in a CD, the best choice is curves described by arcs. Check the dwg
Edited on: Fri, May 6, 2011 at 6:59:50 PM
thanks nastyclown- these are pretty babies- but how do
they lead to a curve where a line smoothly changes radius?
probly need a geometry book like Hub says..
any ideas that pop up will be greatly appreciated..
How to edit a sketch of Extrusion? |
Thu, Aug 1, 2013 at 10:38:11 AM
Curvy roof |
Thu, Jun 12, 2008 at 8:36:34 AM
how can we make the curvy facade in revit 2013? |
Thu, Dec 26, 2013 at 8:45:11 AM
Sketch a path greyed out...can't alter sweep path |
Mon, Jul 26, 2010 at 4:45:05 PM
Sketch up |
Thu, Mar 15, 2007 at 6:46:50 PM
Members: | 2000315 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
