73 Users Online (72 Members):
Forums >> Revit Building >> Technical Support >> The quickest way to show houses in a site map?
15 Posts No Rating |
Hi Guys,
I am currently working on a site plan for a piece of coursework, showing the view from the proposed building out onto the car park, fields and it does look fairly good but there are lots of houses in the distance and I would like to show this on revit. What would be the best was to show the row of houses?
As always, thank you very much for any help.
I see a lot of companies that will use an image from Google Earth otherwise they will use the massing tool generate some generic looking forms (recognizsable of course) and copy those around on the site.
A side note here, you would wise to place all those masses or what have you into a seperate Revit model and link that into your project to reduce the file size and maintain a good level of system performance.
Thank you for the reply - Can I ask how you would use google earth like you said some companies use. How do you go about about?
If you are on subscription, you can use the Globe Link for Revit 2011 plugin.
If not, Imaginit has developed their own...formally called Avatech Utilities
http://imaginit.com/software-solutions/building-architecture/imaginit-utilities-for-revit-2011-named-user
we massing objects of generic shapes.
----------------------------------- PWD |
site map? |
Thu, Oct 4, 2007 at 3:31:36 PM
3D model of a new site with 10 domestic houses on. Need method advice |
Wed, Jun 22, 2011 at 12:25:27 PM
2d Location Map |
Tue, Nov 8, 2005 at 4:58:49 PM
Best Software for Modular houses? |
Thu, May 13, 2010 at 9:30:01 AM
Material image map problem |
Mon, May 11, 2009 at 2:37:29 PM
Members: | 1996349 | Objects: | 22885 | Forum Posts: | 152178 | Job Listings: | 3 |
