182 Users Online (181 Members):
Forums >> Revit Building >> Technical Support >> Problems creating a surface
2 Posts No Rating |
I do the bulk of my conceptual modeling in Sketchup Pro just because I'm more efficient in it than I am in Revit, but now that I am ready to start modeling in Revit 2011, I'm having an annoying problem. I've got a curtain wall that I would really like to model inside of Revit from my original Sketchup model, however I can't just bring it in and use it because the actual surface is not a true surface inside of Skechup. I had to triangulate multiple rectangles and hide the diagonal to give it the illusion of a planar surface. What I was going to try to do was bring the bounding lines into Revit and create a surface by picking the lines of the dwg. Then I was going to model a curtain wall by picking the surface; however, since none of the lines fall in the same plane, picking a reference plane to use while creating the surface is impossible. Does anyone have any tips on how I could do this. I attached some photos from both Sketchup and Revit to give some visual cues as to what I'm trying to do.
Edited on: Sun, Mar 27, 2011 at 3:28:03 PM
2 Posts No Rating |
I don't know why the second visual didn't come along for the ride, but here it is.
Edited on: Sun, Mar 27, 2011 at 3:24:44 PM
Okay, so I have no Idea why both images aren't showing up.
Edited on: Sun, Mar 27, 2011 at 3:29:54 PM
Surface pattern move/align/adjust problems [ 1 2 ] |
Thu, Sep 17, 2020 at 10:29:33 AM
19
Civil 3d surface to revit topo surface |
Thu, Oct 13, 2011 at 7:14:34 AM
Surface pattern problems |
Sat, Jul 23, 2011 at 8:29:46 PM
Creating two surfaces for NGL & Finished, Poche Display |
Tue, Mar 27, 2007 at 5:58:27 PM
Creating irregular patterns with divide surface |
Fri, Sep 28, 2012 at 10:00:35 AM
Members: | 1992676 | Objects: | 22881 | Forum Posts: | 152185 | Job Listings: | 3 |
