Forums >> Revit Building >> Technical Support >> File size issues: Linking multiple Buildings into a Master Site File
41 Posts No Rating |
Hi, We are about to embark on a project that will contain around 20 new buildings, of substantial size, on a single site. Lets say we are modelling an entire university, all at once. Each building will need its own detailed revit file for documentation, and they will all become large files due to the size and complexity of each building. Each detailed building file will then need to be linked (or represented) into a Master Site File containing topography for positioning etc. We have been debating options as to how to link that many large revit files into a Master file without utterly crippling it? We know from past experience that our relatively fast computers simply wont cope with 20 sizable files all linked at once. So the linked files HAVE to get smaller in size. The options as we see them: - Creating small, simple 'placeholder' files to link into the Master Site, containing the external building envelope only. We would have to manually update these 'placeholder' files with any changes. There would be no direct link between the individual detailed building files and our Master site. - Somehow linking only the external envelope of each detailed building file into the Master Site, ie the minimum information necessary to keep file size down. We havent figured out how to do this (yet!). Is there a way to link only a portion of another file? Has anyone come across a similar scenario to this before, or is there a forum that discusses this anyone could direct me to? I have had a good look but nothing Ive found thus far quite covers our predicament. Thanks for your time in advance. Ollie
your going to have to go it with worksets. link in files, turn off worksets that have information you don't need. You might need a ram upgrade if your having problems with large linked files.
21 Posts No Rating |
I agree, worksets will be the best way to control this while keeping a live link. The external envelope may have to be on it's own workset and be the only workset you turn on in tour master file when you link the files.
Worsets will be your answer in multiple ways. First, these buildings should each be linked into the master on their own unique workset. Then you can use reduced worksets to work in the master file turning on only the building(s) you need. Second, each building file should have the site linked into it in a unique workset. The documents will be produced from the building files. Third, the building file should have the shell on a seperate workset. In 2011, we can now control linked file worksetsand this will allow you to control these files in your master file. BTW -(I don't know if this works or not) I would try saving my building file for linking into the master with all worksets off except for the shell. This may helpto reduce memory usage.
Thanks very much everyone, the feedback is appreciated. Youre all pointing in the same direction, linking in worksets and managing file size that way. It sounds like this is the best way to link only a small "portion" of a file whilst maintaining a live link, and thats ultimately what we want to do. Doing some testing, will post anything of interest if & when it happens.
wwhub's suggestion to link just the shell workset will help. however if you link it in and then turn off the worksets, save, close and reopen, you should get the same result.
Site plans and Linking with Master files |
Fri, Jul 7, 2006 at 6:55:40 PM
Linking a linked file... |
Tue, May 2, 2006 at 9:09:31 AM
Linking buildings to a site |
Thu, Sep 16, 2010 at 4:28:48 PM
looking for a keynote master file workaround |
Fri, Apr 3, 2009 at 6:57:06 PM
One site, many buildings |
Wed, Feb 11, 2009 at 8:10:45 AM
Members: | 1992098 | Objects: | 22880 | Forum Posts: | 152184 | Job Listings: | 3 |
