56 Users Online (54 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> Newbies >> Revit 2011 into Sketchup?
Thu, Mar 3, 2011 at 9:41:21 PM | Revit 2011 into Sketchup?
nklank
I've got a client who would like me to email him a copy of the model but he doesn't have revit.  Is there a way to export the revit model into sketchup 8 or some other free modeling software?  I tried a .dwf, dwg, and .fbx and none of these worked.
Thanks a lot!
Nick
Fri, Mar 4, 2011 at 3:39:41 AM | Revit 2011 into Sketchup?
4 Stars: 201 Votes
If you export that in DWG I believe he can open that DWG in Sketchup
Fri, Mar 4, 2011 at 4:01:17 PM | Revit 2011 into Sketchup?
ErikCBAS
Sketchup doesnt take .dwg unless I missed it.  If you do dwf there is a free viewer for it at http://usa.autodesk.com/design-review/
Sat, Mar 5, 2011 at 6:28:51 AM | Revit 2011 into Sketchup?
4 Stars: 201 Votes
"Sketchup doesnt take .dwg unless I missed it" - Just "IMPORT" and select "Dwg - Dxf" format
Mon, Mar 7, 2011 at 8:37:27 AM | Revit 2011 into Sketchup?
ErikCBAS
I have the current version and I dont show anything for importing .dwg. Am I missign something?
Edited on: Mon, Mar 7, 2011 at 8:38:40 AMEdited on: Mon, Mar 7, 2011 at 8:39:53 AMEdited on: Mon, Mar 7, 2011 at 8:40:22 AMEdited on: Mon, Mar 7, 2011 at 8:41:13 AM
Edited on: Mon, Mar 7, 2011 at 10:31:42 AM
Mon, Mar 7, 2011 at 9:30:16 AM | Revit 2011 into Sketchup?
wheelergc
Look under import not open.
I don't want to be interesting. I want to be good.
Mon, Mar 7, 2011 at 9:42:38 AM | Revit 2011 into Sketchup?
Dafpfy
3.5 Stars: 11 Votes
i think you need a (free) plugin to import dwg into sketshup in the newer versions.
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Mon, Mar 7, 2011 at 9:53:27 AM | Revit 2011 into Sketchup?
TKennedy
4 Stars: 7 Votes
If he's willing to install a new program Design Review is free from Autodesk. Then you can send him 3D or 2D DWFs.
Mon, Mar 7, 2011 at 11:35:03 AM | Revit 2011 into Sketchup?
pchan
pchan Avatar
5 Stars: 5 Votes
I prefer to export it as a 3D DWF file since it retains the revit model with all the elements and properties.
and you can use the sectional view (works kind of like section box in revit) to slice thru the model.
I think it give your client to see more than like a solid model.
Sun, Jul 8, 2012 at 5:54:56 PM | Revit 2011 into Sketchup?
kgallemore
I know this is an old thread and I'm sure everyone knows by now that Sketchup FREE does not support and DWG or DXF file import. You must have the Pro version.
Mon, Jul 9, 2012 at 11:18:31 AM | Revit 2011 into Sketchup?
#11
sllana
5 Stars: 2 Votes
You can pass your model to 3dmax and the sketchup does import 3dmaxes. Revit to 3dmax is made by exporting it to dwg (while in the 3d view) first.
Tue, Jul 10, 2012 at 7:01:04 AM | Revit 2011 into Sketchup?
#12
broigutt
You need to have Sketchup pro version to import .dwg files
Sketchup to Revit
Wed, Aug 26, 2015 at 10:41:27 AM
Sketchup model into Revit
Tue, Jan 8, 2013 at 12:06:20 PM
SketchUp to Revit
Sun, Mar 22, 2009 at 6:53:33 PM
Sketchup To Revit Problems *Please Help*
Thu, Mar 12, 2009 at 9:21:29 AM
A little SketchUp with your REVIT ? [ 1 2 3 ]
Mon, Apr 13, 2009 at 3:06:13 PM
34
Page generation time: 2.0262
