85 Users Online (84 Members):
Forums >> Revit Building >> Technical Support >> Peeling paint effect on wall
9 Posts No Rating |
Hi I am trying to create the peeling paint look on the wall, making it peel of the wall (3D) , I have attached a photo of what I am talking about - might be easier to understand. Thank you so much for your help . I am just stuck - not sure what direction to go in. Ananya
You want to create a wall with that effect in 3D??? My advise is: use a good texture (image), don't try to create that in 3D.
9 Posts No Rating |
Yes I want to create that in 3d - I am unable to find any image of exactly what I want - for it to pop of the wall. I just to create simple curls not as detailed in the photo - it is going to the central piece - so needs to work Please let me know if you/anyone can thinkof something. thanks!!!
I suppose I would start by creating a wall hosted family. Use massing, etc within the family to create the various curls and chips, etc, then load it into the project and place on the wall.
Brandon Pike | Owner/BIM Specialist cad.web.print website: http://www.thinkdesign-studios.com blog: http://www.bimtionary.blogspot.com/ |
Here is an idea, I havn't tried it so I don't know how complicated it would be... But you could model just a small piece of peeling paint in 3d, render it then take that render image and export it out as a jpeg, work it over in photoshop to turn it into a mapping image then use your newly created image as your material map. This might give you the effect you desire.
Quote by: Holtz, Lou
How can I paint the wall the color I want? |
Thu, Apr 3, 2008 at 6:59:35 AM
Remove Paint from Walls |
Wed, Feb 9, 2011 at 1:33:46 PM
Changing Wall Paint color |
Sun, Feb 7, 2010 at 7:02:40 PM
Split surface & paint vs. schedule |
Tue, Oct 12, 2004 at 3:34:32 AM
Paint Help |
Wed, May 22, 2013 at 5:33:21 PM
Members: | 1996917 | Objects: | 22885 | Forum Posts: | 152179 | Job Listings: | 3 |
