112 Users Online (111 Members):
Forums >> Revit Building >> Technical Support >> grid layout
118 Posts No Rating |
How can you make the same grid layout applied on every level? Like if I make one change to the grid line, the same change will apply for the rest of the floors?
26 Posts No Rating |
I created grid lines in Revit 2011 in any floor plan and it appears in every one and the grids are links in floor plan views.
----------------------------------- Revit Architecture 2011 Certified Professional |
use the grid command "GR" amd place a grid line. it will move in all levels. try and see
diesellam, You need a better understanding of datum's. Start by reading theis chapter in your HELP: Datum Extents and Visibility. There are 2D settings and 3D settings for datum's- this chapter will tell you how to turn a 2D setting into a3D: Propagating 2D Datum Extents
changing grid lines angle - walls are detached |
Fri, Apr 20, 2007 at 6:29:43 PM
Number of items in grid array |
Fri, Sep 24, 2010 at 6:34:27 PM
Ceiling Grid |
Wed, Mar 16, 2011 at 3:15:50 PM
How do you change the default grid layout when modeling ceilings? |
Tue, Feb 6, 2018 at 10:30:49 AM
Ceiling grid visibility |
Mon, Oct 13, 2008 at 9:10:29 AM
Members: | 1998888 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
