169 Users Online (167 Members):
Forums >> Revit Building >> Technical Support >> Moving the entire model in one file to match the other file
118 Posts No Rating |
Hi, I have 2 different files. One is for Architectural and one is for Structural. Currently, the entire Strucutural model is about 5 feet off of the Architectural model. What's the best way to move the entire Structural model to match the Architectural model?
if you link the structural file into the architectural file, then you should be able to either in '3d view' or section select and move the whole model down. after this you can bind the files together if you choose.
_tom
www.revittutorialsonline.com ::
Open your structural file and acquire coordinates from the Arch link this will but both files to the same 0,0,0 coord system link any new files in using shared coordinates always pin your links to avoind accidental movement of link files, at the bottom of your revit screen I suggest unchecking Press & Drag option... That can be dangerouse tool. If your models still don't line up, find a common base point such as a grid lind crossing and use ID point in your master model to get your coords and then open the linked model and use Specify at point to reassign the common point in your other model to match coord point of your master model. Sometimes, when links get moved or out of line it can be like a dog chasing its tail to realign the models but it is doable. Moving links and/or models should be your last resort.
Quote by: Holtz, Lou
and I would suggest never moving a model, only move a link as a last resort. My fingers got ahead of my brain... I hope this helps
and I meant to say use Specify coordinates at point, not ID point I am getting my Acad and Revit terms mixed up, sorry where is the freaking edit button for this forum? found the edit button, hidden uder the number....
Edited on: Wed, Feb 16, 2011 at 11:14:20 AM
nudging or moving the entire piping system upward vertically |
Fri, May 20, 2011 at 7:26:15 AM
Moving Toposurface. Imported from AutoCAD file. |
Tue, May 12, 2015 at 7:24:19 AM
Moving an entire plan |
Mon, Oct 29, 2012 at 7:31:51 AM
Moving a linked Revit model |
Thu, Nov 21, 2013 at 3:57:59 PM
Importing a cad file |
Fri, Apr 27, 2012 at 3:33:21 PM
Members: | 1999132 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
