56 Users Online (54 Members):
Forums >> Revit Building >> Technical Support >> System Families: Spot Elevation Tag
5 Posts No Rating |
Hi All I have a bit of an problem regarding the spot elevation. I am using the spot tag to show the FFL in my project which indicates the height it is situated in the project, but now I need to add another height to the tag to indicate the sea level offset. Example: My ground floor level is at 0 in my project and the sea level from the ground floor is 16371. I dont want to change my Level heights to an sea level height (It gets confusing). So I want to create an spot elevation tag with both heights (sea level and project level) that looks like this: FFL 0 (16371). Any help or solutions are most welcomed. Thank you in advance
You should really learn to use your HELP. Under spot elevations, you will read this: Elevation Origin If the origin value is set to Project, then the elevation reported is with respect to the project origin. If set to Shared, then the elevation reported is with respect to the shared origin. If the base value is set to Relative, then the elevation reported is with respect to the level in the Relative Base instance parameter. You can change the shared origin by relocating the project. See Relocating and Mirroring a Project. And I don't see any options so this as indicated is either / or.
Edited on: Thu, Jan 20, 2011 at 7:23:37 AM
Spot Elevation tag |
Tue, May 6, 2014 at 12:41:09 PM
Spot elevation Tag and Insulation |
Wed, Jun 11, 2014 at 10:00:27 AM
Invert Elevation Vs. Spot Elevation |
Mon, Apr 20, 2015 at 2:09:11 PM
Spot elevation tag issue |
Mon, Jun 3, 2019 at 3:18:37 PM
ceiling tag to read as spot elevation (top or bottom elevation) (2017) |
Tue, Aug 28, 2018 at 10:51:10 AM
Members: | 1991397 | Objects: | 22879 | Forum Posts: | 152184 | Job Listings: | 3 |
