58 Users Online (57 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> room bounding problem
Sat, Dec 25, 2010 at 3:19:04 AM | room bounding problem
kaldina
Hi,
i am using revit 2011, walls are always coming with room bounding checked. But in this project they are always unchecked room bounding. Every time i have to select wall and make it checked room bounding.Do you know any solution?? Please help me??
Thu, Dec 30, 2010 at 3:33:39 PM | room bounding problem
cganiere
cganiere Avatar
You can select via window, use the filter button to select only walls, and check or un-check the room bounding.
Christopher Ganiere, NCARB, LEED AP
www.developmentone.net
Skype: ArchitectCRG
Fri, Dec 31, 2010 at 6:32:44 AM | room bounding problem
3.5 Stars: 389 Votes
In most instances, Revit defaults to the last used variables but not last set.  Changing a wall to room bounding will not reset this variable.  It needs to be set when placing a wall, not afterwards.
Sun, Jan 2, 2011 at 7:59:22 PM | room bounding problem
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Best bet would be to place all your walls and then when needed select all walls and globally deselect room bounding...
Regards,
Chris.
Wed, Jul 26, 2017 at 11:25:29 AM | room bounding problem
sllana
5 Stars: 2 Votes
Hi you all, I have a problem with room bounding but it is not as simple as checking the parameter. Room Bounding parameter is checked, walls are from 0.00 offset height, all is correct but rooms dont detect the walls. Only walls tha are from first floor to 17th floor are detected as boundings.
Any help will be welcome.
Wed, Jul 26, 2017 at 2:20:52 PM | room bounding problem
The typical problem is that the room is placed on a level different than the walls.   For instance, the plan where the room is placed might be on a structural level and the walls are from finish floor and up.
Thu, Jul 27, 2017 at 9:18:07 AM | room bounding problem
sllana
5 Stars: 2 Votes
Thank you mr wwhub but that is not the case. Im on the same floor plan for both cases. Besides there is no way to choose structural or floor plan for a wall (they are just visualization issues) There is only one Nth level. Isn't there? am i wrong?
Further theories?
Thu, Jul 27, 2017 at 9:34:13 AM | room bounding problem
I don't think you understood my answer.
First - NO phases in your project at all - correct?
Walls have a bottom as well as a top and they can be placed on any level with top and/or bottom offsets.   Rooms are placed on levels and are dependent on the view they are placed from.
You don't say what level you are on but try this.   Use the romm line boundry tool and just draw a box around that toom you placed.   It doesn't need to be in the walls - place it where you can see the results.
Thu, Jul 27, 2017 at 10:01:03 AM | room bounding problem
sllana
5 Stars: 2 Votes
Yes, room boundaries are normally detected (I already had checked that) but there is no way im going to draw room boundary for each room in the project. I need it to work with the walls as it should be.
And as i told before, i put walls being in "floor" plan as well as im trying to put rooms.
and thanks again
Thu, Jul 27, 2017 at 10:05:59 AM | room bounding problem
Why didn't you do the test I suggested?  I am not telling you to draw room boundries everywhere! - Just a small box around your room that you placed in this view.   If you can't understand why then your not thinking.
Thu, Jul 27, 2017 at 10:09:56 AM | room bounding problem
#11
If the room boundry line works then something else is 'leaking' your room.... probably those two columns I see when I looked again at your plan.
Thu, Jul 27, 2017 at 10:21:44 AM | room bounding problem
#12
sllana
5 Stars: 2 Votes
I did that test. That's why i said room boundaries worked. columns are also detected but one level walls don't. I have tried all kind of setting combinations. And believe me, i think a lot. I can make lisp routines for autocad and i work in this kind of programs since 1984.
Thu, Jul 27, 2017 at 5:17:30 PM | room bounding problem
#13
sllana
5 Stars: 2 Votes
Fri, Jul 28, 2017 at 4:03:50 AM | room bounding problem
#14
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Check your room is on the correct level and not a half level or anything like that.
BIG curtain wall room bounding problem!!
Mon, Dec 14, 2009 at 9:31:31 AM
Room Bounding - Room area changes, then changes back for no reason!
Wed, Apr 28, 2010 at 6:22:40 PM
Ceiling not bounding room
Wed, Oct 6, 2010 at 4:01:35 PM
Room Bounding Families
Wed, Mar 31, 2010 at 5:35:10 PM
room bounding parameter in wall
Fri, Jun 27, 2008 at 10:17:07 AM
Page generation time: 0.6704
