82 Users Online (81 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Revit 2011 Curtain Wall Door Template Error
Fri, Dec 3, 2010 at 5:11:05 PM | Revit 2011 Curtain Wall Door Template Error
ktam
Anybody noticed that there is a serious error in Revit 2011 Curtain Wall Door Template.  The Center (Left/Right) reference plane is not truly representing the center.  When you create a door family, it looks right in the family environment when you flex it but when you load into the project, you will see it is off center.  Please see attached pdf.  The way I fixed this is starting creating a family in 2011 with the 2010 template, it will upgrade the 2010 version, do nothing and save it as Door – Curtain Wall.rfa.  Then rename the file as rft, now you have a new template upgraded from 2010.
Sat, Dec 4, 2010 at 5:23:28 AM | Revit 2011 Curtain Wall Door Template Error
4 Stars: 201 Votes
What PDF?
Sun, Dec 5, 2010 at 12:13:52 AM | Revit 2011 Curtain Wall Door Template Error
ktam
Sorry I forgot the attachment.  Here is the pdf file.
Sun, Dec 5, 2010 at 6:36:41 AM | Revit 2011 Curtain Wall Door Template Error
4 Stars: 201 Votes
Turn the Ref. plane Center (left/right) the "Origin"
Sun, Dec 5, 2010 at 2:34:02 PM | Revit 2011 Curtain Wall Door Template Error
ktam
you can try it.  it won't work.
Mon, Dec 6, 2010 at 3:59:46 AM | Revit 2011 Curtain Wall Door Template Error
4 Stars: 201 Votes
I did, that's why I answered.
Mon, Dec 6, 2010 at 8:43:57 AM | Revit 2011 Curtain Wall Door Template Error
ktam
Typhoon,
What version of Revit you are using?  I know you may be using European version.  Mine is 2011 US.  May be there is nothing wrong with European version but I am sure it is not right in the US version.
Mon, Dec 6, 2010 at 8:50:34 AM | Revit 2011 Curtain Wall Door Template Error
3.5 Stars: 391 Votes
I just opened the 2011 template and it is correct.  The opening is centered and the ref plane defines the origin.  Someone may have changed your template so change it back.
Mon, Dec 6, 2010 at 8:54:43 AM | Revit 2011 Curtain Wall Door Template Error
4 Stars: 201 Votes
Ktam, i use 2011 US too, like you can see in my image it flex well in family and in PROJECT, can you put your family here so we can take a look when we can?
Mon, Dec 6, 2010 at 10:31:39 PM | Revit 2011 Curtain Wall Door Template Error
ktam
The problem is when you flex in the family, it looks right but when the door is loaded into the project the center is off. I did a family with just symbolic lines representing the door swings, it is not working.  See attached rvt file.
Tue, Dec 7, 2010 at 10:09:53 AM | Revit 2011 Curtain Wall Door Template Error
Your problem is not the template - it is your family.  Door swings are not easy to do.
Tue, Dec 7, 2010 at 12:09:09 PM | Revit 2011 Curtain Wall Door Template Error
pchan
pchan Avatar
5 Stars: 5 Votes
I tried it with a new template in 2011 Revit Arch and got the same result with in project environment that the swing is off center.
Tue, Dec 7, 2010 at 1:05:52 PM | Revit 2011 Curtain Wall Door Template Error
#13
4 Stars: 201 Votes
Here you have, i just deleted your model lines, create new ones and locked, and i change too the "Center (front/back)" ref. plane to "defines origin".
HTH
Tue, Dec 7, 2010 at 8:44:08 PM | Revit 2011 Curtain Wall Door Template Error
#14
ktam
Typhoon,
This is what I got by using you "CORRECT" family file.  See how the door is offset in the MODEL RVT file.  Do you believe now?
Wed, Dec 8, 2010 at 5:55:30 AM | Revit 2011 Curtain Wall Door Template Error
#15
4 Stars: 201 Votes
Just "Un-Pin" center (left/right) ref. plane, watch the video: http://screencast.com/t/2YfAKaXea5ga
Curtain Wall Panel to Curtain Wall Door
Mon, Jun 23, 2014 at 9:32:11 AM
How to place Curtain/Glass Door for Curtain Wall for Revit Architecture 2012
Thu, Jul 7, 2011 at 4:27:10 PM
Revit 2011 - Curtain Wall doors on Schedule for correct level
Thu, Jun 7, 2012 at 1:22:49 AM
curtain wall door
Tue, Jan 31, 2006 at 1:36:58 AM
Curtain wall door frame
Mon, Mar 2, 2015 at 11:37:33 AM
Page generation time: 2.4132
