Forums >> Revit Structure >> Technical Support >> How to build and import objects
The library here isnt giving me what I need for certain objects. Im an expert modler in Max and was curious if I can build in max and import as .raf file?
----------------------------------- In the day of my trouble I will call for you, for you will answer me.~ Psalm 86 |
"The library here isnt giving me what I need for certain objects. Im an expert modler in Max and was curious if I can build in max and import as .raf file?" do you mean .rfa file?
Yeah, still learnign the nomenclature. Noob here.
In Max you can export in DWG then import in Revit, like i told you before search in Forum what you need and you will find it, BTW, if you look at the bottom of this page you will see similar questions.
The questions at the bottom work some of the time and are vague on the topic and dont precisely offer up an answer sometimes. Keyword search is only as good as its database type. Believe me, Im not new to forums!....lol Thanks for all your help. Ill try to keep the questions down.
" Ill try to keep the questions down." - it's not that, you can keep posting your questions of course but the answers are already here in forum, here you have a simple tutorial from "Maxlloyd" about your question: http://www.revitcity.com/tutorials/how_to_grow_your_family/
Thanks Typhoon.
Import 3D objects from VIZ to Revit |
Wed, Jun 20, 2007 at 12:26:09 PM
Converting AutoCAD ACIS Objects (3D Solid) to Polymesh Objects |
Fri, Oct 12, 2012 at 7:31:58 AM
import dwg surfaces into Revit |
Fri, Mar 6, 2015 at 1:56:09 PM
Best way to build stuff (not "buildings")? [ 1 2 ] |
Sun, Nov 2, 2008 at 4:42:31 PM
24
Using 3D Studio Objects in Revit Architecture 2011 |
Tue, Sep 20, 2011 at 12:09:53 AM
Members: | 1987518 | Objects: | 22875 | Forum Posts: | 152177 | Job Listings: | 3 |
