71 Users Online (69 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> questions
Wed, Nov 3, 2010 at 5:30:55 PM | questions
naomi1234
Can anyone help me some revit questions, please?      1.       How do I enter centre line symbol in revit? So far I only know the code for degree and diameter, could you tell me if you know the code for some other common symbols like autocad has?2.      How can I edit arrowhead in revit. I need an arrow head style which has thick line as head and thin line as leading line.3.      I couldn’t change my wall height. The wall automatically attached to the roof, I unattached it and set the wall height top level to the level that I set in properties, but the wall still shows as raking shape but flat. Can you help me to fix this one, please?
Sun, Nov 7, 2010 at 8:39:05 PM | questions
rkitect
rkitect Avatar
4 Stars: 29 Votes
Answers:
  1. Depends on the font you are using.  If you are using Arial, you're SoL.  There are fonts that do provide these symbols, the one I have found most useful is HandSF
  2. There is a tool in Manage > Additional Settings > Arrowheads  Cryingassuming you're using 2011) that will allow you to edit or define new Arrowhead types.
  3. How did you unattached the wall from the roof?  It sounds like it's still attached.  If you select the wall, in the modify wall panel of the ribbon there is a detach tool.  Did you use that?  Also, walls don't automatically attach to roofs.  There was a dialog after you made the roof asking if you want to attach the wall to it.  Should just be able to use the detach tool as mentioned above to actually detach the top then use the properties to adjust the top level or set it to unconstrained and manually set the height.
HTH!
Edited on: Sun, Nov 7, 2010 at 8:40:09 PM
Please state Revit version being used in your questions [ 1 2 ]
Thu, Dec 15, 2016 at 6:32:17 AM
21
noob with questions and some experience
Sun, Oct 4, 2009 at 5:21:38 AM
Basic Questions
Wed, Dec 16, 2009 at 1:01:10 AM
PME questions and is this the proper forum for PME questions?
Wed, Mar 11, 2009 at 3:28:33 PM
Multiple Newbie Questions
Mon, Sep 23, 2013 at 8:47:23 AM
Page generation time: 0.9889
