128 Users Online (127 Members):
Forums >> Revit Building >> Technical Support >> Removing pesky sound when objects are deleted.
ALL HAIL MATT GROVER
@MATT GROVER
THANK YOU. I OWE YOU MY SANITY.
3 Posts No Rating |
OMG thanks so much for this info, you saved my sanity.
@ MATTGROVER, thanks for the deligence in figuring this out. I've been wanting to rid myself of this for 3 years. It works like a charm
I was not aware that you could use 'backspace' to delete things in REVIT. It is a nice big button maybe I'll start using it.
Hello,
I spoke to our Autodesk dealer. It is not Revit making the sound it was my Windows 7 sound settings. The sound would only happen when i select an object in Revit and hit Backspace. If i hit delete or click on the red X or right click select delete no sound. To fix this issue i went into
Start menu, Control Panel, Hardware and Sounds, Change System Sounds under Sound, in the list of sounds find Exclamation and if it has a speaker by it it is on. Select Exclamation and in the drop down menu below (Sounds) select none. Press ok and try it out. Let me know how it turns out.
Good Luck.
Edited on: Thu, Dec 22, 2011 at 6:11:48 PM"
Thank you so much, you have no idea how that noise was irritating me .... can work in peace now while listening to music!
1 Posts No Rating |
Thank you MattGroverCo for the solution on the sound chime everytime I selected align in Revit, has been driving me nuts for years!!
You have saved my sanity.
thank you, it worked!
Remove Constraints from Deleted Objects |
Tue, Feb 26, 2008 at 4:44:57 PM
Sound Transmission Testing in Revit MEP |
Wed, Feb 29, 2012 at 12:27:43 PM
deleting levels without deleting associated objects on it. |
Thu, Aug 1, 2013 at 6:20:35 AM
Audio Components |
Sat, Aug 14, 2010 at 6:27:41 AM
Sound Isolation Clips |
Thu, Mar 14, 2013 at 4:22:17 PM
Members: | 2004926 | Objects: | 22898 | Forum Posts: | 152183 | Job Listings: | 3 |
