77 Users Online (74 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> Barrier for floor with sloped ramp between levels
Tue, Nov 2, 2010 at 12:09:35 PM | Barrier for floor with sloped ramp between levels
turbeauxpete
Hello all;
I am trying to draw a multilevel parking structure for a class project in Revit Architecture 2010. I have the floors done with the ramps utilizing the modify sub elements tool with no problem. I need to draw a barrier around the edges of the floor including the sloped ramp. I think I need to create a family but I have little experience with that and my instructor ?? is clueless. Could someone recommend a tutorial on the subject or point me in the right direction. I want to learn but not getting much help in class.
Any guidence will be most appreciated
Pete
Houston TX
Tue, Nov 2, 2010 at 1:18:14 PM | Barrier for floor with sloped ramp between levels
lunchtrayrider
3.5 Stars: 7 Votes
hey pete-
there are several ways to do this. a few (but not limited to) include
walls-
 can simply draw a wall and edit each one to look the way you want
railings-
very cool for a cable barrier or such
hosted family-
will be able to slope with the slopes
generic family-
maybe something totally wild or very basic
I like scooters. and motorcycles.
Tue, Nov 2, 2010 at 1:25:16 PM | Barrier for floor with sloped ramp between levels
turbeauxpete
A wall would be perfect, but how do you slope a wall for the ramp? I only want the barrier to be 2 1/2 to 3 foot tall.
Thanks much for your reply
Pete
Tue, Nov 2, 2010 at 2:06:16 PM | Barrier for floor with sloped ramp between levels
4 Stars: 201 Votes
A simple way is: use a couple of "Ref. planes" and attach your walls (Top/Base) to those ref. planes
Tue, Nov 2, 2010 at 2:35:38 PM | Barrier for floor with sloped ramp between levels
wheelergc
Would a slab edge edited to go up instead of down work? That way is stays connected to the floors even if they get moved.
I don't want to be interesting. I want to be good.
Tue, Nov 2, 2010 at 2:39:23 PM | Barrier for floor with sloped ramp between levels
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
if you are going to use a slab edge you have to apply it prior to sloping the floor
Wed, Nov 3, 2010 at 2:12:48 PM | Barrier for floor with sloped ramp between levels
turbeauxpete
Hello Again
I've pretty much solved my problem by modeling in place, solid, sweep as seen in the enclosed project. Just one thing is wrong. The sweep work perfectly except for the left side of the ramp (note: this is just rough example of what I'm trying to do). For the life of me I can't get that section to line up with the rest of the barriers orientation. Any thoughts or suggestions would be appreciated
Pete
Houston
Wed, Nov 3, 2010 at 9:58:50 PM | Barrier for floor with sloped ramp between levels
turbeauxpete
Well I guess I don't know how to attach a file
Thu, Nov 4, 2010 at 6:43:29 AM | Barrier for floor with sloped ramp between levels
4 Stars: 201 Votes
Why do you create that with a Solid Sweep when you can create that with only walls? For those "Sloped" walls, in a Elevation/section view you can edit those walls and draw the shape of that like you want.
Thu, Nov 4, 2010 at 12:30:59 PM | Typhoon
turbeauxpete
Quoting Typhoon from 2010-11-04 06:43:29
 Could you elaborate a little? I see what you are saying but I'm not sure how to do it. I'm brand new to Revit and learning mostly on my own. If you could give me some detail I sure I can learn to do it and learn more at the same time.
Your replies are greatly appreciated.
Pete
in Houston
Thu, Nov 4, 2010 at 2:10:56 PM | Barrier for floor with sloped ramp between levels
#11
4 Stars: 201 Votes
Watch this: http://screencast.com/t/mKV2XvwO6M8B
Thu, Nov 4, 2010 at 2:25:03 PM | Typhoon
#12
turbeauxpete
Pete
in Houston
Thu, Nov 4, 2010 at 2:30:00 PM | Barrier for floor with sloped ramp between levels
#13
4 Stars: 201 Votes
Again???
Thu, Nov 4, 2010 at 3:40:01 PM | Typhoon
#14
turbeauxpete
Pete
in Houston
Thu, Nov 4, 2010 at 4:56:26 PM | Barrier for floor with sloped ramp between levels
#15
4 Stars: 201 Votes
Do you have any doubt or you are doing something wrong when you post? It's the thirth time you post the same question...
Sloped railing on sloped floor/ramp
Tue, Dec 9, 2008 at 9:25:00 PM
How do you host a railing to a sloped floor when the floor is not "typical"?
Fri, Oct 16, 2015 at 9:31:10 PM
Sloped curved ramp...
Sat, Oct 12, 2013 at 8:42:30 PM
12
Attaching double Tees to a sloped floor
Thu, Aug 13, 2009 at 1:23:44 PM
Helical Ramp
Wed, Mar 10, 2004 at 8:51:07 AM
Page generation time: 0.6242
