103 Users Online (102 Members):
Forums >> Revit Building >> Technical Support >> how to make an arc reveal in a wall in revit?
85 Posts No Rating |
I want to make some arc reveal in a wall in revit,but I only fond verticle and horizontal reveals, is there something else method to make a arc reveal in a project wall, not in family.
沧海月明珠有泪 |
Yes, you need to create that in a "In-Place" family, in a elevation view go to "Set work plane" and select the face of that wall, then go to Home>Component>Model in-Place, select the "Wall" category, give it a name, then use a "Void" extrusion with the shape you want, check in a 3D or Plan view if the void is cutting the wall like you want/need, after this use the "Cut Geometry" tool, select the void than select the wall, now you can finish the in-place family.
fairywiner, Did you not read the answer to your earlier post? > "how can I make an arc setback in a revit wall, not openings." I gave you the same answer that Ty gave you now. Please try it and if you have problems, come back.
how to add a self made reveal to a wall while edit wall types? |
Sat, Feb 12, 2011 at 10:53:31 PM
Wall Reveal by Face in 2010 |
Wed, Apr 7, 2010 at 10:20:06 AM
how can I make an arc setback in a revit wall, not openings. |
Mon, Oct 25, 2010 at 1:26:48 AM
Splitting a wall with a Reveal |
Fri, Feb 19, 2010 at 11:25:44 AM
How do i make a foam wall with repeating vertical reveal |
Sat, Nov 18, 2017 at 10:50:48 PM
Members: | 1993875 | Objects: | 22882 | Forum Posts: | 152185 | Job Listings: | 3 |
