164 Users Online (163 Members):
Forums >> Revit Building >> Technical Support >> I want to replace "A/dsk Revit" in T/blk with my own title in Revit 2011
160 Posts No Rating |
I am happy with the standard Revit title block for the moment (AUS) A3 but I do need to change the "Autodesk Revit" part of the title & of course the web address. I have already made a .bmp image of what I want to use can anyone tell men how to load it into the titleblock, please. Then I will be able to start a new (my first paying project in Revit) instead of having to revert back to ACA because of a simple thing like title block customization. Titleblocks do seem a bit harder with Revit !!!
I will be scoring goals soon, I'm in the back line at the moment!
Cheers Dermot
www.dmbd.net |
Import that image (.Bmp) into your titleblock family.
I got it imported & it looks ok but ! it does not print on my local printer but prints of my adobe printer.
Cheers Dermot
www.dmbd.net |
Check your printer settings... Raster / Vector
Try making it a jpg instead of a bmp... You printer may handle that better...
Regards,
Chris.
Co-Founder | BIM Consultant | Software Designer  B. Arch)
Thx I 'll give that a go, I did not realise Rvit would import the jpg
Cheers Dermot
www.dmbd.net |
I changed my imported business title into the Titleblocks instead of the "Autodesk Revit" text using a jpg this time but still with the same results, will not print on my HP A3 printer (its old but it works for my home printer) but when I save as a pdf using the Adobe printer it then prints out fine from there. Not that big a deal as I always print to pdf anyhow, but it would be nice to have it working properly. I found that in AutoCad that I got a better result straight from the Autocad software than via Adobe.
Cheers Dermot
www.dmbd.net |
1 Posts No Rating |
On an HP Plotter you have to go to printer properties, ports. On the bottom of the page is a checkbox that says enable printer spooling. Remove the check from that and your raster image will print. I spent a fair bit of time searching that problem myself. Good luck.
Going from "Title w line" to "Plan Title" |
Thu, Aug 23, 2007 at 11:53:11 AM
assembly |
Mon, Apr 22, 2013 at 5:03:46 AM
Revit/Globe Link 2011 "Aquiring" |
Thu, May 19, 2011 at 1:20:05 PM
Title block printing grey when using "selected views" |
Wed, Nov 29, 2006 at 4:29:49 PM
adding a parameter to "view-title"? |
Thu, Aug 2, 2007 at 4:11:24 PM
Members: | 1995556 | Objects: | 22885 | Forum Posts: | 152175 | Job Listings: | 3 |
