140 Users Online (138 Members):
Forums >> Revit Structure >> Technical Support >> columns grids not recognized
28 Posts No Rating |
I'm new to revit structure and I know I'm missing something that's very easy to fix. I created 6 new grid lines, 3 in one direction and 3 perpendicular to them in the other direction. I modeled a simple pavilion which has only 6 columns and a roof. The column grids intersect each other however when I click on a column the "Column Location Mark" in the Instance Properties dialog box isn't recognizing the grids I created. It's labeling the column a with a distance from another column line in my adjacent building. The only difference I see in the 6 column grids that are not being recognized by revit are that they are on Workset1. The column grid that revit does recognize and supplies a distance from to my pavilion column is on the workset Shared Levels and Grids. I checked my building elevations and I also couldn't find 3 of the column grids in my elevation. Help.
Lock Columns to Grids |
Fri, Nov 2, 2007 at 6:33:27 PM
Grids |
Thu, Dec 15, 2011 at 2:01:34 PM
Structural Columns moving on their own |
Tue, Jun 21, 2005 at 11:10:20 PM
spliting models |
Fri, Dec 10, 2010 at 9:37:48 AM
hidden columns |
Fri, Mar 26, 2010 at 10:53:36 AM
Members: | 2004566 | Objects: | 22888 | Forum Posts: | 152180 | Job Listings: | 3 |
