40 Users Online (39 Members):
Forums >> Revit Building >> Technical Support >> Column Line grids disappear - revit building 2009
60 Posts No Rating |
got a strange one here... for some reason, half my column lines dont show up in all my views except one, a roof plan. they where working fine, I had 7 column lines and when i added 6 more, those 6 show up but not the first 7? Crazy, i have attached an image if anyone has a guess as to what is going on
Col grids and floor levels have limits, they are not infinet in location. When they show in one view and don't show in another, that is because you have to extended them into that view range. In elevations, when you click on one of these elements, you will see either a 2D or a 3D near the end of the reference line. 2D adjustments of these lines are that view only, 3D will adjust the limits for all views. Read this in your HELP:> Maximizing 3D Model Extents
Yes, I would definintely recommend using Scope Boxes to control all your datum extents. Greatly simplifies the management of this.
Regards,
Chris.
Co-Founder | BIM Consultant | Software Designer  B. Arch)
columns grids not recognized |
Wed, Oct 6, 2010 at 9:55:29 PM
Revit Architecture 2012 - Column Grids not Parallel to View will not show up |
Wed, Nov 23, 2011 at 1:27:06 PM
Column Grid Question in Revit 2008 |
Sat, Apr 26, 2008 at 4:56:38 PM
Topo hatch disappear under building pad |
Mon, Jan 27, 2014 at 8:27:53 AM
Grids |
Thu, Dec 15, 2011 at 2:01:34 PM
Members: | 2000203 | Objects: | 22886 | Forum Posts: | 152180 | Job Listings: | 3 |
