61 Users Online (60 Members):
Forums >> Revit Building >> Technical Support >> How do I angle a wall
I need to angle a wall in a 2 story model I am doing. is there anyway to do this, and laso place a window in that wall that is aligned with the angled wall? Thanks
Images please.....
13 Posts No Rating |
In the x and y direction, you can rotate the wall easily. In the Z direction you can use other options, but no, revit doesn't allow that (not that I know of). You can make a wall from in the project using masses. These are not parametric, and probably aren't to good of an idea. You can also create a mass and host the wall on it. The windows and doors do not look good like this. Cheers, Craig Hanus Revit Cafe www.revitcafe.com
----------------------------------- Please visit me at Revit Cafe www.revitcafe.com |
can i associae a curtainwall to a mass, i am using revit 2009. i have a sloped wall, and want to insert a storefront wall into this sloped wall i have associated to a mass
Yes you can. A curtainwall, or Storefront in this case is a wall. Simply change the type from wall 'x' to curtainwall 'y'. Cheers, Revit Cafe www.revitcafe.com
Curtain wall to wall at an angle |
Tue, Jun 12, 2018 at 2:38:49 PM
Wall based embeded angle not keeping hd stud in place. |
Tue, Apr 5, 2016 at 2:49:55 PM
Angle curtain wall |
Thu, Jan 24, 2013 at 3:00:57 PM
Chairail on an angle |
Wed, Jun 22, 2011 at 3:29:35 PM
3D in place sweep problem, changes angle |
Mon, Jan 28, 2008 at 12:56:37 PM
Members: | 1996867 | Objects: | 22885 | Forum Posts: | 152179 | Job Listings: | 3 |
