26 Users Online (25 Members):
Forums >> Revit Building >> Technical Support >> Wall shading
2 Posts No Rating |
I would like to see the layers of my new and existing wall assemblies in Medium/Fine detail view in plan while I am working on them, but switch to Coarse view before printing. In Coarse view, I would like new walls to be shaded grey in plan, and existing walls to be white.
If possible, I would like to avoid having 2 of each wall type, one shaded and one white.
I thought I had this worked out with the Phase overrides and Phase Materials, but it doesn't seem to work as I expect.
![eldados Avatar](user_avatar/6083.jpg)
![4.5 Stars: 8 Votes](/images/stars_4.5.gif) |
you need to control it from the wall properties, define the coarse pattern or shade you want...
2 Posts No Rating |
I can do this, but I want the same wall type wall to appear differently if it is existing than if it is new. The override does not work as expected; I can get the exist. white in New Const Phase but in an Existing Phase view, it is shaded. (Same Filter: Show All.)
Wall Materials and shading. |
Fri, Jan 30, 2009 at 4:01:22 PM
New wall trasparent shading. |
Thu, Jun 15, 2017 at 7:46:15 AM
Shading Toolbar |
Tue, Jun 22, 2004 at 9:54:36 PM
Mesh Sun Shading Device |
Fri, Apr 16, 2010 at 1:52:54 PM
TOO DARK Shading with Edges Revit 2009 |
Mon, Aug 25, 2008 at 6:57:19 PM
11
Members: | 2009917 | Objects: | 22931 | Forum Posts: | 152196 | Job Listings: | 3 |
