132 Users Online (132 Members):
Forums >> Revit Building >> Technical Support >> Slabs in some views showing up as tone.
2 Posts No Rating |
Hi, In Revit 2009, I'm having my slabs in a single view show up as toned. I have tried to override surface pattern, I've checked view depth to make sure I wasn't cutting through it. I've even changed the tone of the surface of the conc slab, and nothing. This was happening on two machines in the office, and is now happening on 3 of them. Any ideas?
Are you working with Phases (existing/new)? in that view go to properties and check....
2 Posts No Rating |
The phases checked out. I ended up playing around with the paint command, and after painting it its original material, then undoing it, it fixed the problem. Weird eh?
Floor slabs showing dashed instead of Solid |
Wed, Jun 5, 2013 at 5:53:00 PM
12
Cut pattern under graded region or slabs not showing in plan [ 1 2 ] |
Tue, Jul 22, 2008 at 5:13:50 PM
18
Import a dwg without it showing in all views |
Fri, Apr 29, 2016 at 10:25:47 AM
Half Tone Visibility for Roof gutter |
Mon, Jul 11, 2011 at 12:06:30 AM
Trying to get a handle on this half tone control |
Wed, Jun 20, 2012 at 9:56:06 AM
Members: | 2000934 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
