41 Users Online (39 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Join geometry in a family
Fri, Aug 27, 2010 at 10:52:11 AM | Join geometry in a family
nirim
5 Stars: 12 Votes
Hi there
I attached simple family of a chimney that I insert over slate roof, the problem is that when I join the lead tile to the chimney to create a nice visible join the material (or the visibility in another family) of one become the material of the other even though I gave each of them different material parameter. Any suggestion?
nirim
Fri, Aug 27, 2010 at 11:41:42 AM | Join geometry in a family
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I was able to join the chimney to the roof with 'shakes' material without a problem.
I think you have software issues.
Edited on: Fri, Aug 27, 2010 at 11:42:07 AM
Tue, Aug 31, 2010 at 3:17:37 AM | Join geometry in a family
nirim
5 Stars: 12 Votes
Hi dgcad
Back from long weekend (hence the delay in reply). I am not fully understand your answer, do you mange to join both lead flashing and the chimney pipe Crying inside the family) and yet maintain each of the elements’ materials deferent?
nirim
Tue, Aug 31, 2010 at 8:27:18 AM | Join geometry in a family
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
nirim,
I think I understand your question and the answer is this. Within a Family, when you use join geometry, the second object "inherits" the material (including materal parameters) of the first. It will also inherit any visibility settings. So if you need seperate material parameters you will need to leave them unjoined.
In your chimney family you can use a Void to "cut" the geometry that you don't need off the bottom of the chimney.
Edited on: Tue, Aug 31, 2010 at 8:34:34 AM
Tue, Aug 31, 2010 at 8:59:57 AM | Join geometry in a family
nirim
5 Stars: 12 Votes
Hi JAMESHFRIMES
Thanks, your answer is spot on. Problem with using void to cut the pipe, is that the pipe angle (relative to the lead flashing) is changeable, to adjust the chimney to whatever roof pitch.
I wish the REVIT people will make something about it, it is rather fundamental to family construction.
nirim
Tue, Aug 31, 2010 at 9:17:58 AM | Join geometry in a family
You can set the void to be an angle cut to match the roof.  Is that how the boot is made?
Tue, Aug 31, 2010 at 9:36:43 AM | Join geometry in a family
TKennedy
4 Stars: 8 Votes
A void works. It just has to be large enough to always cut the pipe. Just make sure that the only thing the void cuts is the pipe, and you should be good to go.
Tue, Aug 31, 2010 at 9:37:46 AM | Join geometry in a family
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
Check this one out
Tue, Aug 31, 2010 at 10:01:46 AM | Join geometry in a family
nirim
5 Stars: 12 Votes
Thanks, work like a treat.
nirim
join geometry problem
Wed, Jan 27, 2010 at 5:53:31 AM
Cut / Join - Geometry (api)
Tue, Jul 29, 2008 at 2:07:19 AM
Parallel walls join geometry do not cut opening
Fri, Jan 31, 2020 at 1:32:48 PM
Column Join issue
Wed, Oct 11, 2017 at 10:10:15 PM
Revit Structure 2008 SP2: Join Geometry on differnet beam families
Wed, Sep 19, 2007 at 11:58:38 AM
Page generation time: 2.6228
