113 Users Online (112 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> IF ( AND ( ) ) logic with multiple Yes/No paramters
Tue, Aug 17, 2010 at 11:38:26 AM | IF ( AND ( ) ) logic with multiple Yes/No paramters
Kobbs
Kobbs Avatar
Okay, I've read through pretty much all the topics here regarding logic, logic operators, syntax etc. Massively helpful, but I now have a problem that I can't quite solve.
I'm sure it must be possible, and suspect that I'm just typing some part of the logical expression incorrectly.
I am making a room tag that reports 4 pieces of information, the room name, occupancy, area and space use. Making the tag is no problem. I also want to be able to control the visibility of the occupancy, area and space use labels. This is also easily done with a simple visibility yes/no parameter.
The problem I have is that if for example I didn't need the occupancy label to be displayed, I don't want a blank line where that label has been turned off. I want the other two labels to 'move up' to fill the space. For this reason I have created duplicate labels, which in theory will sit on top of each other, and only become visible when certain conditions are met.
Take a look at the screenshot, I have moved the duplicate labels across to the right for clarity, but the labels in each row would normally all be on top of themselves. What I am trying to do for instance, is that if the visibility of the Occupancy label was turned off, but Area and Space Use still needed to be seen, then the Area 2 and Space Use 2 labels would turn on, and the others would turn off.
In effect the logical statement for the visibility of the above (in my head!) would be IF 'Occupancy' = NO, 'Area 2' = YES AND 'Space Use 2' = YES.
I'm sure I'm supposed to be using the IF ( AND (....... , ........) ... , ... ) statement, but can't seem to find a way to express the above in a way that Revit understands.
EDIT: In case it makes any difference, I'm using Revit Arch 2010. Thanks guys!
Edited on: Tue, Aug 17, 2010 at 11:40:57 AM
Tue, Aug 17, 2010 at 4:23:51 PM | IF ( AND ( ) ) logic with multiple Yes/No paramters
TKennedy
4 Stars: 7 Votes
Ok, I think I got something working. I can't really explain, but if you open up the attached family you should be able to reverse engineer it.
Wed, Aug 18, 2010 at 6:43:16 AM | IF ( AND ( ) ) logic with multiple Yes/No paramters
Kobbs
Kobbs Avatar
You are officially my Hero!
*swoon*
Hey, I have this old Rubik's cube lying about, maybe you could help me out with that!
Tue, Feb 8, 2011 at 10:39:35 AM | IF ( AND ( ) ) logic with multiple Yes/No paramters
emgeeo
3.5 Stars: 7 Votes
Thank you for that fine example of Yes/No logic statement writing.
Thu, Sep 22, 2016 at 4:15:48 AM | IF ( AND ( ) ) logic with multiple Yes/No paramters
mhkashfi
Thank you TKennedy!!!
Windows showing up gray in consistent colors view.
Thu, Feb 13, 2014 at 9:20:21 AM
Parametric Void within a Solid
Fri, Aug 27, 2010 at 10:24:07 AM
Multiple project north[s]
Fri, Apr 15, 2016 at 3:15:11 PM
11
Grouping multiple families types with multiple options
Mon, Jun 11, 2012 at 3:50:19 PM
Multiple Levels..Many Multiple levels..
Fri, Jan 21, 2005 at 7:06:26 PM
Page generation time: 0.3661
