161 Users Online (160 Members):
Forums >> Revit Building >> Technical Support >> revit not opening
my question is we hav a guy here in the office that when he opens revit 2010, the initial revit screen splash comes up for 20 seconds or so and then closes before it has a chance to open. any ideas on what the issue maybe. we have unistalled and reinstalled and get tht e same result. thanks in advance
----------------------------------- PWD |
i should ad that is working fine, then this started to happen
This is probably due to a conflict with the communications center. delete the file WSCommCntrData.xml found at c:\Documents and Settings\%USERNAME%\Local Settings\Application Data\Autodesk\Revit\%REVIT VERSION%\ENU\Components\Web Services
that did it, all better now. not sure what would have caused that file to go bad, other than last wednesday our building was hit by lighting and everything shutdown instantly. and that is when it started, it was a bad hit we lost power for 6 hours and elevators for 4 days and our office is on the 6th and top floor. thanks for the tip
Glad that worked out for you!! Not sure what causes it but we have had it happen on several machines for no apparent reason.
My guess is it's internet explorer related.
I've had trouble with this myself, AutoDesk Support told me to reopen in another administrator and start over. What a pain. I'm going to try this. Thanks alot, Brettgoodchild.
Floor and shaft opening issues |
Fri, Nov 4, 2016 at 3:41:50 PM
Arched Opening Problems |
Tue, Jan 18, 2005 at 5:06:11 PM
Opening cut and Void cut not allowed |
Thu, May 2, 2013 at 2:29:16 PM
Door family - opening covers door leaf |
Fri, Sep 30, 2016 at 4:36:46 AM
Introduction / wall irregular shaped opening |
Wed, Mar 26, 2014 at 6:57:30 AM
Members: | 1998633 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
