180 Users Online (178 Members):
Forums >> Revit Building >> Technical Support >> 2011 quirk, with cursor/property fields
This seems to be a new feature in 2011... If you select a field in properties with text to change, such as the top offset of a wall, yet move your cursor back over a view, the text field selection is dropped. This has led to a lot of frustration for me, because I usually delete the contents of a field prior to giving it new properties, and so when I mouse over a view after selecting the properties box, I delete the actual object I'm selecting, instead of the value in the box I had selected a fraction of a second before. It took me a long time to even figure out which old habit was being disruptive. My problem is that to work fast, I often have my cursor hovering over the next object on my mental to-do list while my other hand is typing out a number. It is inefficient to have to leave my cursor over a text field for the duration of typing in that field. When I want back in a view, I'm HAPPY to just double click it to interact. Has this bothered anyone else? Is there a setting to turn this off? I hope I've been clear in describing my grievance..
I noticed this to VERRYYYY ANOYING. By the way it's the same in A-CAD2011. When annybody knows how to turn this of please tell, REALY FRUSTARATING!!! Luckilly I never use the del, I just click (move my mouse away) and start typing. This way I don't end up deleting the selection. Maybe another way to work alround is enlarging the properties menu so the pointer won't get "outside" the menu.
Cursor not visible in schedules, Revit Structure 2014 |
Tue, Apr 29, 2014 at 2:16:15 PM
Multiple dimension fields in schedule |
Wed, Aug 24, 2011 at 4:31:08 PM
Property Paint Revit 2011 |
Fri, Jan 14, 2011 at 3:54:51 PM
Fomatting Row Height in Schedules |
Thu, Feb 27, 2014 at 3:15:04 AM
Schedules combining 2 text fields in to 1 |
Fri, Aug 10, 2007 at 12:27:28 PM
Members: | 1995254 | Objects: | 22882 | Forum Posts: | 152183 | Job Listings: | 3 |
