80 Users Online (79 Members):
Forums >> Revit Building >> Technical Support >> Revit Import IFC Options not working?
20 Posts No Rating |
Now that ArchiCAD 14 has the ability to assign their slabs into floor and ceiling categories, the ceiling elements get exported to IFC under the IfcCovering class, which is correct. When opening the same .ifc file in Revit Architecture 2011, the ceiling slab is categorized as a Generic Model, not Ceiling. According to the Revit Import IFC Options, it clearly shows the IfcCovering to be imported into the Ceiling category, which is not working. I have an IFC viewer that confirms the ceiling slab is an IfcCovering so the broken link is occuring in the Revit importing. Any suggestions? If I should report this to Autodesk, can someone tell me who or where? I know Generic Model elements can change categories but when I change it to the Ceiling Category, I still don't have the ability to change it to another ceiling type. The best thing I can do is copy the extrusion outline and paste it into a new ceiling form. Thanks for your help. ksymons
Edited on: Fri, Jul 2, 2010 at 10:34:57 AM
2 Posts No Rating |
HELLO DID YOU HAVE ANY GOOD SOLUTION ON YOUR PROBLEM? BECAUSE I HAVE THE SAME ONE AND CANNOT FIND ANY SOLUTION? THANKS DANAI
No Import - Maximum size of IFC imports? |
Sun, Jul 10, 2016 at 6:56:30 AM
Revit export/import to IFC - ceilings and floors (ifccovering) |
Mon, Jul 28, 2014 at 3:22:58 PM
Revit MEP IFC Export - Objects not detalied |
Wed, Jul 2, 2014 at 8:08:29 AM
IFC import intoRST2010?.. |
Fri, Mar 26, 2010 at 2:07:17 PM
IFC file import |
Tue, Jul 26, 2011 at 3:15:08 AM
Members: | 1990825 | Objects: | 22877 | Forum Posts: | 152180 | Job Listings: | 3 |
