40 Users Online (38 Members):
Forums >> Revit Building >> Technical Support >> Stand Alone 3D Rotatable Object
4 Posts No Rating |
We do theatrical and AV design and as such we need to create stand alone objects that can be rotated in 3 axis (x,y,z). A good example of this is speakers, which hang in free space (not hosted) and need a vertical tilt angle (pitch), horizontal rotation angle (roll), as well as a a yaw adjustment (at times). I can create a family that allows me to build various size and shape speakers by driving type parameters for length/width/etc. but when I insert them into a model it is impossible to rotate them in section to get a vertical aiming angle (how can Revit not have this basic function??). I have searched all over the web but not found anything that speaks to this situation. Help?!
In the family editor under parameters and settings is a "keep vertical" switch. Un-check that and now you can rotate your speaker. If you need these angles reported, you could build the rotation in your family using shared parameters.
Edited on: Wed, Jun 23, 2010 at 10:30:10 AM
4 Posts No Rating |
I've tried that, but it doesn't seem to help.
I'm sorry but what I posted does work because I have used it many times. Are you using embedded families? A good tool to help you understand how to build families is the families guide available here: http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=13080413&linkID=9243097
4 Posts No Rating |
My goal is to have a file that contains all the similar models from one manufacturer. This could be used as a stand-alone, but I will most likely want to nest it in another file to reduce the number of items the user sees and to create reporting parameters for certain values. I have attached the base family - if you put it in a project, go to a section view, and try to rotate it you will get an error. Note that the 'always vertical' box is not checked.
Read these posts on AUGI: http://forums.augi.com/showthread.ph...speaker&page=3 http://forums.augi.com/showthread.php?t=118549&highlight=rotate
4 Posts No Rating |
Thanks - this is really helpful! I figured somebody had to have run into this before...
ROTATABLE NORTH ARROW BUT NOT TEXT |
Sun, Jun 3, 2018 at 8:30:19 AM
Embedded Detail Component and Object Styles |
Fri, Feb 12, 2010 at 3:21:25 PM
Rotatable North Arrow |
Mon, Dec 29, 2008 at 6:02:48 PM
Object parameters |
Mon, Jul 28, 2008 at 12:53:06 PM
Mr GGs metric parametric coat hat umbrella stand |
Fri, Jan 4, 2008 at 4:06:18 PM
