183 Users Online (182 Members):
Forums >> Revit Building >> Technical Support >> window opening doesn't show in floor plan view
2 Posts No Rating |
I have adjusted the view range cut plane to view windows but then I can't see the doors. I can't understand why all the windows and doors will not show if they are located between the Primary Range. I read something about changing the family but that will affect all my windows. Do I need to change the wall to allow the windows and doors to be viewed together. The window sill starts at 7' the door height is 6'10"
2 Posts No Rating |
OK I found it! Yes it's adjusted in the visibility portion in the options bar when you select to edit a family. every attachment can have different visibility within the family. Also different view selection,which there are many, can be set in thefloor plan view itself. I think this area "views" could be covered all in a serious tutorial. Don't look at me.
Window family doesn't cut properly in plan |
Wed, Aug 14, 2013 at 6:55:42 AM
Why doesn't my window display in plan? |
Tue, Sep 15, 2015 at 3:09:42 PM
Roof doesn't show up on floor plan |
Wed, Feb 6, 2019 at 10:43:46 AM
Wed, Aug 5, 2015 at 6:44:07 AM
Cant see stairs in opening in plan view |
Wed, Nov 26, 2014 at 10:35:34 AM
Members: | 1993695 | Objects: | 22882 | Forum Posts: | 152185 | Job Listings: | 3 |
