43 Users Online (42 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> turning off levels below current on your sheet view
Fri, May 28, 2010 at 5:38:31 PM | turning off levels below current on your sheet view
bellgroup
Can someone explain to me how to turn off levels below the one that is current in my sheet views. I'm looking at the secound floor plan and can not get rid of the 1st floor below it. It is kind of confusing.
Thanks very much
Sat, May 29, 2010 at 5:07:43 AM | turning off levels below current on your sheet view
4 Stars: 201 Votes
In that view, type VP (view properties) then in "View Range" check the "Bottom and View Depth"...
Sat, May 29, 2010 at 6:58:41 AM | turning off levels below current on your sheet view
coreed
coreed Avatar
4 Stars: 16 Votes
if you have the underlay option on, you will have to go to that view and in the view proprties set the underlay to none
hth
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Mon, May 31, 2010 at 1:47:26 PM | turning off levels below current on your sheet view
bellgroup
Thanks for your responce once again. I have set the view range up higher but it did not resolve the issue. I noticed in a 3D that the walls extend up and slope with the rafters. This is the reason they have not completely disappeared. In the second FP that i'm trying to get rid of the underlayment the only walls still show ing are the ones that are on the 1st floor closer to the ridge (the center of the house) which is were the walls would be the highest point. I have tried setting the top constraint of the walls to the second floor but I did not get the walls to edit at all. Is it due to there not being a floor system above the 1st floor are should the wall stop at the level anyhow.
Tue, Jun 1, 2010 at 9:35:48 AM | turning off levels below current on your sheet view
TKennedy
4 Stars: 7 Votes
It sounds like you attached the walls to the roof. Select the walls and detach them.
Wed, Jun 2, 2010 at 3:32:26 AM | turning off levels below current on your sheet view
coreed
coreed Avatar
4 Stars: 16 Votes
post some images of the issue.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Thu, Jun 10, 2010 at 11:05:39 AM | turning off levels below current on your sheet view
bellgroup
I do have one more question if you do not mind. I need hatch patterns and rendering image for stone if you know were I can get them for Revit.
Thu, Jun 10, 2010 at 11:07:16 AM | turning off levels below current on your sheet view
4 Stars: 201 Votes
Search in "Download" section, you have lots of patterns there...
Thu, Jun 10, 2010 at 12:19:11 PM | turning off levels below current on your sheet view
bellgroup
Thanks, but do you know of any other location that I could go to.
There was not much there on the subject I was searching.
Turning off one view title tag without turning them all off
Thu, Feb 22, 2007 at 6:27:42 AM
Current Revision Date in sheet index
Mon, Nov 2, 2009 at 11:22:28 AM
Revit Linked View is turning to Host View after Synchronizing
Thu, Feb 23, 2017 at 3:32:39 PM
Levels/ sheet view box accidently deleted
Mon, Nov 12, 2012 at 2:27:05 PM
Turning off views on a sheet
Fri, Jul 17, 2009 at 8:43:04 AM
Page generation time: 2.1014
