63 Users Online (62 Members):
Forums >> Revit Structure >> Technical Support >> Revit Structure 2010 won't start!!! Help!!!
10 Posts No Rating |
This fix works on Revit Structure, MEP, & Architecture as well in the 2010 & 2011 release. The official Autodesk solution to the Revit Won't Run or Start Up issue is to delete the WSCommCntrData.xml file in the folder listed above.
Greg Bates ManagedDesignInc www.ManagedDesignInc.com |
I opened a support ticket at Autodesk and the help that I got was less than satisfactory. This is what I ended up doing. Just a follow up for Chris Aquino Autodesk support team. My products seemed to start doing the same thing again. I got a tip from RevitCity forum said to “delete the file WSCommCntrDATA.xml found at C:\documentsand settings\user\localsettings\applicationdata\autodesk\revitversion\enu\components\webservices” Guess what , it seems to work. There appears to be an internal conflict within the Autodesk system you guys should fix. Several other people have reported this problem. If you think that I have made a mistake to delete that program or if you can let me know what it’s purpose is I would appreciate a reply. Thank you Steve Carnes
1 Posts No Rating |
This worked perfectly!!! OMG THANK YOU!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
1 Posts No Rating |
Deleting "WSCommCntrData.xml" worked for me.
To locate "WSCommCntrData.xml" to delete it see http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15145616&linkID=9243099&CMP=OTC-RSSSUP01
this should work for all disciplines of Revit 2010 (Architecture / Structure / EMP) on windows XP and Windows Vista / Windows 7.
Revit won't start again (i have to restart) [ 1 2 ] |
Thu, May 26, 2011 at 6:07:37 PM
20
Revit 2010 won't start up |
Tue, Sep 28, 2010 at 4:32:52 PM
revit won't start |
Thu, Nov 3, 2005 at 10:50:45 PM
Unable to start robot analysis structure (HELP NEEDED) |
Tue, Apr 29, 2014 at 10:11:09 AM
Metalic Structure in Revit Architecture |
Fri, Dec 3, 2010 at 1:10:10 PM
Members: | 1999341 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
