72 Users Online (70 Members):
Forums >> Revit Building >> Technical Support >> WALLS BELOW
WHEN ON A SECOND FLOOR SHEET IF I HAVE ATTACHED A WALL TO THE ROOF THE FIRST FLOOR WALL SHOWS BECAUSE THE WALL RAISES THROUGHT HE CUT PLANE. IF I HIDE THEM THEY AE GONE ,B UT DOING THAT HEY RETURN WHEN PLOTTING. HAS ANYONE RAN INTO THIS ALSO.
----------------------------------- PWD |
admin
why are your first floor walls going through the cut plane of your second floor? Make sure they are not taller than they should be... Also, the hide/isolate tool is only for temporary use, it doesn't work for printing and goes away as soon as you close the view.
Hiroshi Jacobs
The Catholic University of America |
what it is, is that when i attach a first fl;oor wall to a gable roof it now raises into the second floor cut plane. a common example in my area would be a garage on the house that has a gable on it, so the wall tops out at second floor bearing so i them attach the top to the gable roof over the front garage wall.
do you now anything about my other post about window and door numbering is that something i need to place in the family or do i need to change it per project. i get confused with type and tyoe mark since both are different numbers. it seems to pull the type mark rather than type.
Attaching Rails to walls |
Thu, Aug 13, 2009 at 12:59:42 PM
Walls |
Thu, Dec 16, 2004 at 4:56:57 PM
solid walls transparent to curtain walls and railings in back.. |
Mon, Oct 29, 2012 at 7:34:26 AM
Foundation walls & Normal walls joint, linework tool? |
Sun, Nov 1, 2009 at 12:24:18 AM
Inner walls overslaping outer walls. |
Sun, Dec 14, 2014 at 4:58:35 PM
