74 Users Online (73 Members):
Forums >> Revit Building >> Technical Support >> revit crashes when adding picture to page setup
7 Posts No Rating |
I have edited the standard page to include my own title block but when i try to add a .jpg picture revit crashes?
what do you mean by "standard page"?
7 Posts No Rating |
the sheet where you drag the items required to be printed
What Revit Version? Try to convert that image to DXF file ...
Not Sure What Revit Can Do?... Find it OUT!!!
“Imagination is more important than knowledge...” -Albert Einstein |
"what do you mean by "standard page"?" I guess this is Revit Title block already done by autodesk like the templates lets say right murphy?
"What Revit Version? Try to convert that image to DXF file ..." you can't convert a raster image to dxf ??, atleast i don't think you can. lots of people add raster images to there title blocks, never heard of that causing a crash. sometimes they won't print. hopefully someone will have some insight to your problem.
Did you try with other image format (extension) like PNG or TIFF?
titleblock not lined up with page |
Fri, Jan 13, 2006 at 1:32:44 PM
Autocad Export - Page Setup Manager |
Fri, Mar 27, 2009 at 9:03:29 AM
Texture - adding new into matrial library from picture |
Mon, Oct 10, 2005 at 5:51:42 AM
RVT to DWG export page layout settinigs |
Fri, May 11, 2012 at 3:31:01 PM
Page Setup |
Sun, Jan 13, 2008 at 6:58:28 PM
Members: | 1991959 | Objects: | 22879 | Forum Posts: | 152183 | Job Listings: | 3 |
