80 Users Online (79 Members):
Forums >> Revit Building >> Technical Support >> Using a void to create an opening in a swept blend?
40 Posts No Rating |
Hello, I'm trying to create a complex wall form in revit 2010 right now. To do this I am using a swept blend Modeled-in-place component, and then trying to add a void to it to cut through the form where I need an opening. I've created the wall and the void, but whenever I go to finish the model it says: [quote]Some Void Forms of this family do not cut anything and will be deleted. To make a Void Form cut something else use the Cut Geometry tool.[/quote] I've used voids to create holes in extrusions for families I've made before, shouldn't it work the same for this? Does anyone know how to fix this?
Never mind, I was intersecting along the bottom line and this was preventing it.
Swept Blend |
Fri, Nov 28, 2008 at 4:39:26 PM
Please help me with swept blend!! |
Mon, Jul 28, 2014 at 3:31:14 PM
swept blend with more than 2 profiles |
Sun, Nov 18, 2012 at 5:21:23 PM
Swept Blend for Basin |
Tue, Oct 31, 2017 at 3:38:16 AM
cannot rotate the reference plane of a swept blend |
Tue, Feb 23, 2010 at 6:22:35 AM
Members: | 1998769 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
