127 Users Online (126 Members):
Forums >> Revit Building >> Technical Support >> AUTOCAD LINKED FILE QUESTION
26 Posts No Rating |
GOODMORNING ALL, I HAVE A MEP PROPOSAL THAT I AM WORKING ON, AND TO SAVE TIME I AM GOING TO LINK AN AUTOCAD DWG. IN TO MY MODEL TO PROVIDE A BACKGROUND. THE PROBLEM I AM HAVING IS THE LINK WILL ONLY SHOW UP IN A SINGLE PLAN VIEW. IS THERE A WAY TO HAVE THE CAD LINK VISIBLE IN ALL PLAN VIEWS, AND STILL MAINTAIN THE VISIBLITY DEPTH SET UP FOR A PERTICULAR PLAN. OR DO I HAVE TO IMPORT THE LINK INTO EVERY LEVEL???? THANKS
I'm unsure what you mean by the visibility depth -- in my experience, it's the default for imported autocad files to be visible on all floors. You could check your visibility settings, and see if imported families are turned off in some. Or, if I am mistaken, (only worked on projects with three floors) You could created a level for your imported autocad file, and set this as your underlay for your views, if you aren't actively using other floors as underlays.
Linked AutoCAD file printing grey |
Mon, Jul 26, 2010 at 10:07:25 PM
Invalid Dimension to linked AutoCAD file. |
Tue, Mar 13, 2007 at 11:24:22 AM
Problem with autocad linked file |
Fri, Mar 2, 2018 at 12:24:23 PM
autocad linked files and refresh |
Tue, Apr 7, 2009 at 2:12:36 PM
exporting to autocad |
Fri, Aug 31, 2012 at 7:35:41 AM
Members: | 2001100 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
