130 Users Online (129 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Tips & Tricks >> Converting Ceiling Based families to Face Based Families
Wed, Mar 3, 2010 at 8:20:26 PM | Converting Ceiling Based families to Face Based Families
smitholino
It has been very frustrating to me that ceiling and wall based MEP families do not attach to linked architectural models. This limitation has been dealt with somewhat in Revit MEP 2010 in that some families come now as face based such as swithches and receptacles, but the vast majority of availble families are still wall or ceiling based, so what do you do?
Last night I discovered the answer.  Rather than painfully reconstructing the family in a new face based model, you can nest the ceiling or wall based family in a new face based model.  You can load the old family into a model, and then using the Component command attache the ceiling based family to the face of the face based family.
There are a few drawbacks.  MEP connections do not nest, so after you insert the ceiling based family into the face based family you will need to recreate the MEP connections, and define them properly.  They will attach to faces in the nested family.  If you want the new family to cut the face you will be attaching it to in the project, you will need to make a new Void extrusion, make sure it cuts only the face extrusion, and move it into place.  Here are the steps:
  1. Start a new Generic Face Based Family.
  2. Under the Family Properties tab click on Category and Parameters.  Change it to match what you need, such as Air Terminals, or Lighting Fixtures.
  3. Load the ceiling or wall based family into the new face based family.  This can be done by clicking on the Insert tab and using the Load Family command, by having the ceiling based family open and clicking on the Load into Project command and selecting the new face based family, or if you don't have any component families loaded, click on the Component command and when the dialog box comes up giving you the option to load a family choosing that and loading the ceiling based family.
  4.  Use the Component command and place the nested family.  You can use either Place on Face or Place on Workplane.  Using the Place on Workplane will make so that you can cut a void in the face extrustion any size, and don't need to worry about leaving a bit of face under the nest family.
  5.  Align the nested family origin with the reference planes in the new family.
  6.  If you want the family to cut a hole in the face that it will be attached to, create a void in the appropriate place in the face extrusion.
  7. Set type parameters as needed such as Default Elevation, Manufacturer, Model, Omniclass, etc.
  8. Set up type parameters to match parameters in the nested family, and link them to the parameters in the nested family.
  9. If you need to add MEP connections, add them to match the connections in the nested family.  You might need to have the nested family open for editing to be able to determine what they need to be
  10.  Save the new Face Based family, and test it in a project file to make sure it behaves like you expect.  Make any needed adjustments.
 It only takes 5 to 10 minutes to do this, and can save countless hours recreating families.
Thu, Mar 4, 2010 at 11:44:50 AM | Converting Ceiling Based families to Face Based Families
cedwards
This is exactly what I've been looking for but I'm having some problems with you instructions.
I can start a new family and load my existing wall based family into it, but the problems occurs when I insert the component.  When I try to insert it, I don't have an option to place on face or workplane.  If I could do this I could finish the process.  Attached is family I'm trying to make face based.  Any help on the would be greatly appreciated.
Thu, Mar 4, 2010 at 12:06:47 PM | Converting Ceiling Based families to Face Based Families
smitholino
I apologize, but I tested it with a wall mounted plumbing fixture - at least the description said it was wall mounted, but when I looked at it again this morning, the family was actually face based.
 I know it works for ceiling hosted, but it looks like I was premature when I said wall mounted.
Tue, Jul 27, 2010 at 5:45:29 AM | Converting Ceiling Based families to Face Based Families
robrevit2009
Thank you for posting this suggestion.
Don't think it works in every situation.
I am trying to use it to convert a ceiling based sprinkler to a faced based one, but like the previous poster I don't get the option to place by face when nesting it into the generic face based family.
Mon, Aug 20, 2012 at 12:44:56 AM | Converting Ceiling Based families to Face Based Families
makico
I did all that you said, but when try to insert it's only can be inserted on a ceiling. There is no "pick face to insert" option.
Tue, Jun 12, 2018 at 7:13:41 PM | Converting Ceiling Based families to Face Based Families
yangarchtwork2
JUST MAKE WHATEVER MOUNTED OBJECT INTO GROUNP TWO THREE TIME. THEN IT CAN BE FREE FLOW OBJECT IN SPACE.
Scheduling Problem with Face Base Families
Tue, Jul 15, 2014 at 8:59:16 AM
face-based lighting fixture families questions [ 1 2 ]
Fri, Oct 24, 2008 at 12:17:51 PM
15
Plan annotations for face based families
Tue, Feb 8, 2011 at 8:59:45 AM
How would you modify a family from face-based or hosted to one that is not?
Mon, Sep 26, 2011 at 8:39:50 AM
Face-Based Sinks on Countertops
Fri, May 13, 2016 at 12:14:08 PM
Page generation time: 0.7785
