103 Users Online (102 Members):
Forums >> Revit Building >> Technical Support >> Callout box & dimension line visibility
4 Posts No Rating |
Revit Architecture 2009: Is there a way to toggle a callout box to sit behind dimension lines, or is this more of a layering item that is controlled by which tool was utilized first? The issue is that we are adding text for clarity to some dimensions, and redrawings all the dimensions & ensuring the text edits are all accounted for will be time consuming. There has got to be something I'm missing. Any help would be great!
Please clarify. I'm not sure what you are doing. An image would be great.
----------------------------------- BallewDesigns.com |
4 Posts No Rating |
See attached. I dimensioned the plan first, and then I needed to add callouts, and this is the result.
Roof Detail Callout Visibility? |
Tue, Aug 8, 2006 at 5:48:07 PM
Hiding Elements In a Callout |
Thu, Aug 26, 2010 at 12:18:49 PM
Dimension Crop Box |
Wed, Oct 21, 2015 at 3:17:51 PM
Detail callout vs. Floor plan callout |
Mon, Nov 2, 2009 at 11:03:39 AM
Dimension line fixed distance from an Object |
Tue, Aug 22, 2017 at 8:18:26 AM
Members: | 1995466 | Objects: | 22882 | Forum Posts: | 152175 | Job Listings: | 3 |
