36 Users Online (35 Members):
Forums >> Revit Systems >> Technical Support >> Electrical Panel Boards
ok, i'm confused. using mep2010. i have a panel that is 120/208, and a piece of equipment that is 1 pole, 208. i can't get the two to connect unless i change the equipment to 120v. should this be happening? this makes the information in the equipment schedule to be incorrect.
Try to learn at least one new thing every day |
1 Posts No Rating |
Make the equipment 2 pole, 208v (single phase). For instance, duplicate a disconnect switch and rename to whatever you'd like, make the voltage = 208.00v and no. of poles = 2, then save and load into project.
adding existnig loads to electrical panel |
Tue, Feb 23, 2010 at 9:32:02 AM
Custom MEP Electrical Panel Schedule |
Fri, Jul 13, 2012 at 1:45:21 PM
Modifying Electrical Panel Voltages |
Wed, Feb 11, 2009 at 10:42:57 PM
Existing Electrical project |
Thu, Oct 22, 2009 at 10:03:23 AM
Electrical Panel Schedules - Space numbers |
Wed, Sep 3, 2014 at 2:49:40 PM
Members: | 1994630 | Objects: | 22882 | Forum Posts: | 152181 | Job Listings: | 3 |
