54 Users Online (22 Members): Show Users Online - Most ever was 428 - Mon, Nov 12, 2007 at 5:48:43 PM
Forums >> Revit Building >> Technical Support >> insert a cad file in section or elevation..
Tue, Feb 9, 2010 at 8:25:39 AM | insert a cad file in section or elevation..
durgeshbrijwasi
Joined Wed, Jul 9, 2008
i am trying to link a cad file ... but by default it is going in the plan view...how do i insert it in a elevation or an section..???
Tue, Feb 9, 2010 at 9:55:39 AM | insert a cad file in section or elevation..
site moderator
Joined Tue, May 22, 2007
4 Stars from 109 Votes
Go to a elevation or section view, then insert the cad file.
I Hope and I Wish to LEARN more, and more, and more.... REVIT
Tue, Feb 9, 2010 at 10:43:23 AM | insert a cad file in section or elevation..
durgeshbrijwasi
its still not happening.....
Tue, Feb 9, 2010 at 12:39:06 PM | insert a cad file in section or elevation..
gprakash
Joined Fri, Apr 24, 2009
While importing CAD drawings, did you check the option 'Current view only' ?
Tue, Feb 9, 2010 at 12:50:54 PM | insert a cad file in section or elevation..
durgeshbrijwasi
YES I DID....
Tue, Feb 9, 2010 at 1:17:52 PM | insert a cad file in section or elevation..
site moderator
Joined Tue, May 16, 2006
3.5 Stars from 82 Votes
What you have been told is the correct process.  You must be doing something different.
Tue, Feb 9, 2010 at 1:22:57 PM | insert a cad file in section or elevation..
durgeshbrijwasi
ok then.. i ll keep trying...thanks
Wed, Aug 11, 2010 at 9:49:31 PM | insert a cad file in section or elevation..
allisonkapler
Joined Wed, Feb 10, 2010
Im having the same problem, did you figure it out? I also for some reason cant see my building in two of the elevation views and when I create a new elevation all the curtain wall is missing, any suggestions?
Wed, Aug 11, 2010 at 10:18:23 PM | insert a cad file in section or elevation..
itsmyalterego
itsmyalterego Avatar
Joined Fri, May 29, 2009
4 Stars from 1 Votes
If you go to visibility and graphics-->imported categories, is the box "show imported categories in the view" unchecked??
Wed, Aug 11, 2010 at 11:58:23 PM | insert a cad file in section or elevation..
nastyclown
Joined Tue, Jul 14, 2009
Drag and drop it to an elevation... never phails
RA 2008:: Detail components out of place on 2d element insert from file
Fri, Jun 6, 2008 at 1:22:57 PM
Importing a METRIC CAD survey file generates topo lines at wrong elevation
Thu, Aug 12, 2010 at 2:40:21 PM
Linking CAD file with GEO Marker - RAC 2010
Wed, Sep 23, 2009 at 9:58:21 PM
Phases and Elevation or Callout Marks
Sat, Sep 26, 2009 at 1:49:53 PM
Importing a cad file
Mon, Nov 3, 2008 at 11:24:25 AM
Page generation time: 0.5704
