40 Users Online (38 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Design option or what?
Wed, Feb 3, 2010 at 12:08:47 PM | Design option or what?
arusso5
Okay, maybe I'm not using the design options correctly, but here is my dilemma...
I have a project that may have a second floor over a portion of the building, depending on how the pricing comes in.  Which means I have to show both options (bar joists, metal deck and insulation, epdm roof as base bid and cold formed framing, concrete deck as alternate) in the set.  I have the pieces in the design options correctly, but i need to be able to show building sections with both options in the dd set.  Am I correct in saying that you can only show one design option at a time?  Is there a way to have a building section duplicated to show the alternate framing?
And if not, how do I go about this dilemma?
Thanks in advance.
Wed, Feb 3, 2010 at 12:37:12 PM | Design option or what?
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
I have not tried this but perhaps in the phases you could create two different phases and then the sections could change. Otherwise two different models.
Wed, Feb 3, 2010 at 1:42:13 PM | Design option or what?
cbieser
1 Stars: 1 Votes
You should create different views showing each design option.  Under VG, design options tab, set to "option 1" (or whatever you've named it).  Duplicate the view and then in that view set it to "option 2".  ONLY ONE MODEL IS NECESSARY.
Design Option Issue - walls in 1 design option cutting thru a 2nd option
Thu, Oct 21, 2010 at 11:55:04 AM
Design Option view setting
Fri, May 16, 2014 at 8:02:11 PM
Design Options - black hole.
Wed, Feb 14, 2007 at 12:54:40 PM
Design Option Sharing
Mon, Dec 6, 2010 at 10:02:19 AM
12
Railing wont host to stair created in design option
Mon, Oct 24, 2011 at 3:54:39 PM
Page generation time: 0.5413
