46 Users Online (45 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Learning to render in revit
Search this ThreadSearch this Thread | Page 3 of 3 | << Previous 1 | 2 | 3
Wed, Mar 24, 2010 at 1:37:37 AM | Learning to render in revit
#31
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
good work table-
see the image..
Wed, Mar 24, 2010 at 1:51:25 AM | Learning to render in revit
#32
vector23
vector23 Avatar
2 Stars: 16 Votes
the picture on the right looks so real i can imagine
someone actually walking around those bushes
and in that walkway.. the one on the left looks
worse than a fake magazine picture..
Wed, Mar 24, 2010 at 2:20:43 AM | Learning to render in revit
#33
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
okay table listen to this:
this all boils down to the bounce or the no bounce
option.. depending on the scene- sometimes the
2 bounce option looks better than the 1.. with the 1
bounce you need to lighten of the shadows like i said..
with the 2 bounce you "reset" the exposure dialog to
default..
for the most part the 2 bounces looks a little more
UNNATURAL.. think about that.. to calculate light is hard
enough- but to calculate it bouncing all over the place
is near impossible.. but on the other hand- that extra
bounce fills in the dark shadow areas and MAY look
better..  so try the same render with the 2 bounces
and the exposure set to "reset default"..
Wed, Mar 24, 2010 at 3:41:13 AM | Learning to render in revit
#34
lahiwal
how can i get best interior rendring......plz plz help
Wed, Mar 24, 2010 at 3:59:15 AM | Learning to render in revit
#35
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
Interior rendering is a serious art.. if you look at a lot
of professional interiors you will see lots of light bounces
and relections and minipulation of light.. but i think just
simple interiors are fine for just selling something like
a house design.. here is an example of a simple
interior without a lot of light manipulation and
interior decorating and furniture..
Wed, Mar 24, 2010 at 5:03:35 AM | Learning to render in revit
#36
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
table- but you need to know that even though
i told you about being able to use 2 bounces- i
will never do it.. it's just way too unnatural for me..
so the first way you did it with all the settings i
gave you- that is the best way in my opinion..
Thu, Mar 25, 2010 at 4:20:03 PM | WYS1WYG
#37
tabletennisman
Quoting WYS1WYG from 2010-03-24 02:20:43
default..
I think this looks more unrealistic as you said.
http://img691.imageshack.us/img691/5770/3dview2.jpg
I suppose i'm happy with the actual building in the previous render. I just need to use a brick texture that tiles better.
 What about grass? There must be some site i can download or buy grass that looks realistic? As well as plants.
This for example:
http://3dviz.com.au/images/adenbrook/Lakewood_Seville_Folio.jpg (the grass and plants in particular)
Thanks for your help!
Thu, Mar 25, 2010 at 5:02:34 PM | Learning to render in revit
#38
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
table- that 3Dviz render looks great- BUT you need to be
a professional render artist to do that.. and they are rare..
of course any image that looks artistic rather than real
will sell better.. but if YOU and I try to add light bounces and
lighting effects it will look terrible.. that's why i just
render with no bounces and no lighting effects- just
full precision illumination and full soft shadows- that's it..
and that's the most real looking image you can get..
but if you want to play with artistic affects go ahead..
also there are many more artistic light setting in 3Ds Max
than there is in revit.. same render engine though..
Thu, Mar 25, 2010 at 5:12:51 PM | Learning to render in revit
#39
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
also table- if your computer is that slow and you don't
want it to take so much time- make it a less MB size..
my computer renders that exact same scene
in 25 min.. and if i buy the new i7 processor it
will render in 10 min..
Thu, Mar 25, 2010 at 5:21:04 PM | Learning to render in revit
#40
tabletennisman
My computer at work here is getting old. It's only a dual core athlon 4200+ with 2GB ram. That last image took 10 hours to render.
And i understand about the lighting - vray and 3dsmax probably come into play to get those sort of results.
Can you make any comments on grass and plants? Where i can get them from? One that contains actual leafs of grass, rather than an image tiled across the surface that doesnt look realistic.
Thu, Mar 25, 2010 at 6:12:40 PM | Learning to render in revit
#41
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
the kind of trees you are talking about is where
the leaves are made with polygon lines.. accurender
used those kind of trees.. and yes you can find many
of those kind to use with mentalray.. and at first that's
what i was thinking too- but now i'm used to the photo
trees and i'm finally convinced that they really do work
better.. they make a contrast to the building.. where
the trees are an imaginary setting and the building is
real.. the people who created this rendering program
have figured all this out.. and in the end they are usually
right..
New to Revit :) Learning to Render *Tips Appreciated ;)*
Fri, Sep 4, 2015 at 12:49:11 PM
Can I use Viz4 or Viz Render after design with Revit?
Wed, Feb 22, 2006 at 10:24:37 PM
Learning Revit, College [ 1 2 ]
Mon, Aug 30, 2010 at 5:20:51 PM
25
Distance Learning Seminars
Tue, Oct 24, 2006 at 3:36:21 PM
Can I use full version revit learning resources to learn revit lt?
Sun, May 22, 2016 at 7:15:43 AM
Page generation time: 1.8069
