62 Users Online (61 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Learning to render in revit
Search this ThreadSearch this Thread | Page 2 of 3 | << Previous 1 | 2 | 3 Next >>
Thu, Mar 18, 2010 at 4:08:46 AM | Learning to render in revit
#16
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
table- you render with revit- revit has the best rendering
engine in the world.. 3Ds Max has the same rendering
engine but it's much more clumsy to render in Max..
Thu, Mar 18, 2010 at 4:20:23 AM | Learning to render in revit
#17
tabletennisman
care to explain how i can make my rendering look far better than it currently does - that image you attached looks a million times better than my efforts.
Is it the textures i'm lacking? Where can i get good textures? The rendering stage i'm currently at, i have no idea how i can improve the actual rendering quality and realism...
Thu, Mar 18, 2010 at 6:16:00 AM | Learning to render in revit
#18
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
okay table-
i'm going to put this together in a step by step way for you to
get exactly that quality rendering on anything you want to
render.. i just need to make sure i get every step in order
for you so you don't have to ask me about something i
left out.. this is the end of my day right now- but just
check back here in about 12 hours and i will have
it right here for you.. as everyone knows i'm not
the revit expert i should be after five years
with revit- but i AM a render expert- at least.. lol
Thu, Mar 18, 2010 at 6:25:50 AM | Learning to render in revit
#19
tabletennisman
dead set champion! Will really appreciate it Smile
Thu, Mar 18, 2010 at 8:24:38 PM | Learning to render in revit
#20
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
okay table i'm back..
as you can see in this thread there are some render
masters here..
hisdirt for one clearly understands what rendering is..
and yes rendering is very exciting.. but i hope it doesn't
distract you too much from learning to create construction
documents like it has with me.. lol
i read what everyone is saying here about rendering and it's
all true- but i thought i would show you how to get a good
rendering step by step and then you can learn the theories
later..
although even to walk you step by step to a good rendering
i need to explain the bare minimum of theory..
first thing i will say is that i'm only going to be talking about
EXTERIOR rendering here.. interior rendering is a horse
of a different color..
but let's get this one theory out of the way..
you know like when you go to YouTube and you can choose
the low res version of the video or the HD version?
well that is basically what you should think about with rendering..
the low res rendering version is done in about 3 minutes- and the
the high res rendering is done in about 20 minutes- (depending
on the power of your computer)..
the one you do in 3 min is just for quick looking at
what you got- like if you are building something and you want
to see how it actually went together- or you want to see that
everything is the way you want it before you make a PRESENTATION
rendering..
there is only ONE number you want to look at to determine
if it's going to be a high res or low res- it's the MB number with
PRINTER selected and not screen.. (forget about ever selecting screen)..
the only difference between a low res render and a high res
is that a high res is just rendered at a LARGER SIZE (MB)- and then
SHRUNK down so it becomes high res when you print or view it..
(you also need to know how to resize images in paint)..
so that's the FIRST thing to get planted in your head- and
this image i attached points out what i've said here.. don't
worry yet about how to make these settings- just understand
what we have so far..
oh yeah one thing i forgot to mention is that you always
render your scene within the crop region..
some of these things you will already know but i have to
go from start to finish..
let me know here when you understand everything
about this first part so i can go on to the second part..
Thu, Mar 18, 2010 at 8:40:46 PM | Learning to render in revit
#21
tabletennisman
Yep i'm with ya. Cheers for taking out the time to help. Same goes for the others who have contributed too!
Thu, Mar 18, 2010 at 8:41:08 PM | Learning to render in revit
#22
tabletennisman
Thu, Mar 18, 2010 at 10:40:05 PM | Learning to render in revit
#23
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
okay now remember you want to decide if you
will render the scene low or high res.. and like
i said you watch that MB number on the main
render dialog..
once you understand this second part
you will be 2/3 an exterior render expert..
look at the image of this main dialog and
try these things out and when you got
it down good we will move on to the last
part- custom render settings..
let me know if you have any questions about
this main dialog before we get into custom settings..
Thu, Mar 18, 2010 at 11:04:54 PM | Learning to render in revit
#24
tabletennisman
yep have that dialogue grasped.
Sun settings are really personal preference yea? Choosing the time of day to get the desired shadows etc? Not sure if you'll be mentioning this in the custom settings.
Cheers.
Thu, Mar 18, 2010 at 11:16:01 PM | Learning to render in revit
#25
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
sun settings and clouds and all that can be
anything- it doesn't matter- EXCEPT
sometimes the building looks a little better
with shadows going in one direction instead
of another.. but you can mess with all that
later.. also though- the location and time
of day is good to learn later too.. a photographer
will always choose the best time of day to take
the photo.. i'll be back with the last of this in
a couple of hours and then you can render..
Fri, Mar 19, 2010 at 1:48:31 AM | Learning to render in revit
#26
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
okay table- here you go-
get the crop region around your scene the way you want it..
hit the render teapot..
select printer as opposed to screen..
make it show 15MB..
hit "adjust exposure" and put shadows at the very minimum..
now go back up to the top of the render dialog and drop down
the "setting" field and select "edit"..
i attached three images to show exactly the way to
set all the sliders and check boxes..
once it starts rendering uncheck that timer dialog
so it doesn't close when the rendering is done so
you can make a note of how much time it took..
then export the image as a .bmp if you want to
save the sky or background color- or .tiff if you
want the highest quality printing- but you will
lose any background or sky.. probably best
to just select white color for the background
in the first place for now and export .tiff..
let me know how it goes..
Fri, Mar 19, 2010 at 5:29:41 AM | Learning to render in revit
#27
Revin
This is without a doubt the most awesome and informative thread on this site so far...
WYS1WIG and Trombe, you are legends! Thanks a mil!
Sat, Mar 20, 2010 at 3:08:54 AM | Learning to render in revit
#28
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
two things i can point out about rendering
that is good to know is:
1. if there is a lot of geometry in the scene
it will take longer to render.. if you only have
one square box to render there is not much
computer work to calculate the light and shadows
for just a box.. but if it's a building with dozens of
surfaces- that will take some more time to render..
2. that "adjust exposure" dialog- you can change
those settings AFTER the render is finished..
i just go ahead and put the shadows at the bottom
because i don't run any light bounces and that
makes the shadows a little lighter- so i set it
to be slightly darker to make up for that..
but again- you can do anything you want
with those exposure controls after the render
is done..
Sat, Mar 20, 2010 at 3:13:25 AM | Learning to render in revit
#29
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
opps- typo- correction
not-  i don't run any light bounces and that
but- i don't run any light bounces and that
makes the shadows a little DARKER- so i set it
to be slightly LIGHTER to make up for that..
Tue, Mar 23, 2010 at 4:06:43 PM | WYS1WYG
#30
tabletennisman
Quoting WYS1WYG from 2010-03-19 01:48:31
make it show 15MB..
Thanks mate... see attached rendering below. All settings used as you said, 15.1MB, took 10 hours 54 to render!!!
http://img180.imageshack.us/img180/6199/3dview1.jpg
I'm still not happy with it. To be honest i don't notice a difference between the settings i'd used and what you'd said... It's gotta be my textures that are lacking?? Where's the best place to download (or possibly buy) materials and textures that actually look good?
Cheers!
New to Revit :) Learning to Render *Tips Appreciated ;)*
Fri, Sep 4, 2015 at 12:49:11 PM
Can I use Viz4 or Viz Render after design with Revit?
Wed, Feb 22, 2006 at 10:24:37 PM
Learning Revit, College [ 1 2 ]
Mon, Aug 30, 2010 at 5:20:51 PM
25
Distance Learning Seminars
Tue, Oct 24, 2006 at 3:36:21 PM
Can I use full version revit learning resources to learn revit lt?
Sun, May 22, 2016 at 7:15:43 AM
Page generation time: 1.8531
