50 Users Online (49 Members):
Forums >> Revit Building >> Technical Support >> Edit Split Face on Ceiling
15 Posts No Rating |
I have a gypsum ceiling in which I have to integrate some acoustic tiles. I am using the split face command so I can apply a different material to each different face. Making multiple ceiling every time I have a different material on the ceiling will make the file too heavy. Now I have to edit the split face region because I have to modify the dimensions. I am not able to edit the split face lines, even using TAB! There is no way I am able to select a line or a face created by the Split Face command so I can modify the alignement! Is there any solution other than redrawing the ceiling every time I want to make a change or making different ceilings for each material(which is to heavy!)?
Why don't you select by "Crossing" then go to the "Filter" tool and select only what you want?
When I do a Crossing selection and then Filter it by choosing Split Face, it selects only the face and I am not able to do any modification to the face exept moving it (and copy, mirror, etc). What I want to do is to select a line from the splitted face and to move it. I want to edit the splitted face boundary. Any suggestions?
See the video and tell me if this is what are you trying to do: http://screencast.com/t/MjlmMTk2Mz
This is exactly what I was trying to do! My problem was that the "Edit Boundary" function wouldn't appear because I had several Splitted Faces selected. Now I am selecting only one at a time. Thanks a lot! very helpful!
Actually, I had splitted the same face twice ; this is why when I crossed selected the ceiling it detected 2 splitted face.
Or you can model the ceiling as you're building it. In other words, sketch the ceiling(s) as intended and change the type(s) of the ceiling, rather than using a split face tool. In my opinion, editing a ceiling is a lot easier to do than editing a split face. Plus, you can schedule it more accurately if needed.
"If you tell the truth, you don't have to remember anything" |
Modifying Split Face |
Thu, Feb 18, 2010 at 6:07:10 AM
Split face for multi colored wall |
Wed, Oct 7, 2020 at 3:18:11 PM
SPLIT FACE BLOCK |
Tue, Jul 18, 2006 at 10:41:24 AM
split surface hides surface aligned component families |
Wed, Jul 31, 2019 at 7:37:57 AM
split face tool on curved extrusion |
Thu, Nov 20, 2008 at 3:33:50 PM
13
Members: | 1991621 | Objects: | 22879 | Forum Posts: | 152184 | Job Listings: | 3 |
