84 Users Online (83 Members):
Forums >> Revit Building >> Technical Support >> Revision Numbers
8 Posts No Rating |
Yes, that's all I'm asking for, is the OPTION to use 0 instead of 1. But we got our package issued (as Rev 0) and it's all good.
Thanks to everyone....
1 Posts No Rating |
came across this thread while trying to fix the problem where setting a revision to "none" for its numbering causes it to not show up in the automatic populating drawing index. Fixed this by setting it to "alphabetic" and inserting a "-" as the first character in line. to me this is better than using the O as a 0.
Stupid question: how do you keep from showing any numbers for the issue / revisions. Revit is adding a number that it doesn't seem like should be doing.
crwinchester,
I just tried it in 2014 and had no problems. I even added the cloud first while it was numbered and then switched it back and that worked too.
Since you didn't say which Revit, I then tested it in 2015 and no problem there. Perhaps you are not up to date on your updates.
I used Alphabetic Numbering and changed the sequence to be "ABØ"
revision leters instead of numbers |
Mon, Mar 6, 2006 at 7:15:55 AM
Revision schedule showing revision sequence numbers with empty descriptions |
Thu, Feb 28, 2013 at 3:46:03 PM
Scheduling revision nunbers |
Tue, Oct 13, 2009 at 9:57:04 AM
Revision Schedule not updating |
Tue, Aug 28, 2012 at 7:59:18 AM
Revision numbers |
Wed, Jan 23, 2008 at 10:12:53 AM
Members: | 1998354 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
