81 Users Online (80 Members):
Forums >> Revit Building >> Technical Support >> Cavity Wall Around Bay Not Showing Correct Detail
78 Posts No Rating |
Hi I've been racking my brains about this for some time now and can't seem to figure out why the cavity wall around a curved bay is different to the other cavity walls. I created the wall using the same wall type etc, but the wall appears to be greyed out as opposed to the other walls clearly showing the cavity etc. When I look in 3d view, the wall looks fine, but in plan view, you can see the difference. I have attached an image for you to look at if this will help Thanks Kirk
----------------------------------- USING REVIT 2011--- This old builder is determined to Learn Revit no matter what it takes. |
Your curtain wall is embedded in the cavity wall and so you only see the top of the wall below. As such, you will not see the cavity.
Thanks
Cavity Wall - Cavity Not Filled |
Mon, Jun 16, 2008 at 5:42:38 AM
Column in a cavity wall |
Wed, Oct 24, 2007 at 4:55:44 PM
Joining Cavity wall with separating wall |
Mon, Jul 14, 2014 at 9:12:31 PM
cannot get rid of lines join cavity in wall |
Fri, Sep 12, 2008 at 8:31:29 AM
Joining different Cavity walls |
Mon, Jan 5, 2015 at 12:26:43 PM
Members: | 1995013 | Objects: | 22882 | Forum Posts: | 152183 | Job Listings: | 3 |
