56 Users Online (55 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> MOVING DIMENSION TEXT
Fri, Sep 2, 2005 at 12:14:12 PM | MOVING DIMENSION TEXT
RevitStructure1
WHEN I MOVE TEXT FROM A DIMENSION, IT IS TRAILED BY AN ARC. IS THERE ANY WAY TO MAKE IT A STRAIGHT LINE?
Sat, Sep 3, 2005 at 1:39:40 AM | RE: MOVING DIMENSION TEXT
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Not that i know of... its either curved leader or none at all...
Mon, Apr 23, 2007 at 5:25:43 PM | MOVING DIMENSION TEXT
Modelman
If you keep dragging the dimension out and down the line will become horizontal as it lines up with the main dimension line.  This is about the best visual affect you can achieve.
Sat, Apr 28, 2007 at 10:26:26 PM | MOVING DIMENSION TEXT
DaveF
Hi
Is there a way to have it turned off by default?
Dave F.
Sun, Apr 29, 2007 at 6:37:03 AM | MOVING DIMENSION TEXT
latemore
latemore Avatar
3 Stars: 2 Votes
like most things in good ole revit,there is usually a way to do such things.  if you select the dimension, an option pops up in the options bar, to select/deselect leader.  i have learnt over time to really watch that bar, and the explanation bar along the bottom.
Mon, Apr 30, 2007 at 4:50:01 AM | MOVING DIMENSION TEXT
DaveF
Yes, I'm aware of the option to turn it off after the individual dim is drawn, but I was enquiring if there was a way to have all dimensions default to no line before they're drawn.
Mon, Apr 30, 2007 at 5:34:39 PM | MOVING DIMENSION TEXT
latemore
latemore Avatar
3 Stars: 2 Votes
hi dave
sorry but it appears it is a post-operation option only.  might be a wishlist thing.  i do not find it too onerous i must admit, as the dimensioning in revit is fairly intelligent overall,
peter
Mon, Apr 30, 2007 at 9:49:52 PM | MOVING DIMENSION TEXT
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
As a general rule (as i hate that leader as well).  I leave the leaders on until i finish dimensioning and then do a select all instances of a particular dimension type and deselect leader to turn them all off at once.
It would be nice to be able to have them be off by default.
Regards,
Chris.
Tue, May 1, 2007 at 4:05:42 AM | MOVING DIMENSION TEXT
DaveF
 Thanks to both for replying.
The one bit of dimensioning that still seems to be missing is for curved wall widths (thickness).
 At the moment I'm having to add temp reference plans (see attached). Iis there abetter way?
 Cheers
Dave F.
Dimension Text [ 1 2 ]
Tue, Jul 8, 2008 at 9:15:07 AM
18
Overwriting Dimension with Text
Thu, Jan 11, 2007 at 11:13:56 AM
Multiline text below dimension
Tue, May 10, 2011 at 9:32:42 AM
Dimension Text Problem
Fri, Nov 14, 2008 at 9:41:55 PM
Inserting text under dimension in string dimension
Thu, Apr 2, 2009 at 9:47:51 AM
Page generation time: 0.9001
